[Geoserver-users] Adding YSLD-Styles through REST
Hello,
I am trying to add YSLD-Styles through Rest equivalent to this Documentation of SLD-Imports: http://docs.geoserver.org/stable/en/user/rest/api/styles.html
At the end of the first section it says: “Other extensions (such as css) add support for additional formats”.
Unfortunately I haven’t found any documentation for the YSLD-extension regarding this issue.
Is there nevertheless any way to import YSLD-Styles via Rest or is that just possible by converting them into SLDs?
I am using the GeoServer 2.10 Version.
Thomas
Hi Thomas,
it should be possible to import YSLD-Styles via REST.
Here are some snippets (curl commands) from a script that we were using to do this:
Step 1: Create the style
curl
-v
-u $USER:$PASSWORD
-XPOST
-H “Content-type: text/xml”
-d “
$YOURSTYLE
ysld
$YOURSTYLE.yaml
1.0.0
http://localhost:8080/geoserver/rest/workspaces/$YOURWORKSPACE/styles
Step 2: Upload the style
curl
-v
-u $USER:$PASSWORD
-XPUT
-H “application/vnd.geoserver.ysld+yaml”
–data-binary @$YOURSTYLE.yaml
http://localhost:8080/geoserver/rest/workspaces/$YOURWORKSPACE/styles/$YOURSTYLE
Step 3 (optional): Assign style
curl
-v
-u $USER:$PASSWORD
-XPUT
-d “
$YOURSTYLE
$YOURWORKSPACE
http://localhost:8080/geoserver/rest/layers/$YOURWORKSPACE:$YOURLAYER
Good luck,
Nils
Am 07.12.2016 um 12:23 schrieb Thomas-Maximilian.Cuerten@anonymised.com:
Hello,
Thomas
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today.http://sdm.link/xeonphi
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Dipl.-Inf. Nils Bühner
— Anwendungsentwickler —
terrestris GmbH & Co. KG
Kölnstr. 99
53111 Bonn
Tel:   +49 (0)228 / 96 28 99 -54
Fax:   +49 (0)228 / 96 28 99 -57
Email: [buehner@anonymised.com](mailto:buehner@anonymised.com...)
Web:   [http://www.terrestris.de](http://www.terrestris.de)
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH
vertreten durch: Hinrich Paulsen, Till Adams
Hi Nils,
Thank you for your quick reply. Your commands helped a lot and the import finally works!
Is there any chance that something like this finds its way to the documentation?
Thomas
Von: Nils Bühner [mailto:buehner@anonymised.com]
Gesendet: Mittwoch, 7. Dezember 2016 13:28
An: Cürten, Thomas Maximilian; geoserver-users@lists.sourceforge.net
Betreff: Re: [Geoserver-users] Adding YSLD-Styles through REST
Hi Thomas,
curl
-v
-u $USER:$PASSWORD
-XPOST
-d “
$YOURSTYLE
ysld
$YOURSTYLE.yaml
1.0.0
curl
-v
-u $USER:$PASSWORD
-XPUT
curl
-v
-u $USER:$PASSWORD
-XPUT
-d “
$YOURSTYLE
$YOURWORKSPACE
Good luck,
Nils
Hello,
Thomas
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comourceforge.net)
Kölnstr. 99
53111 Bonn
Email: [buehner@anonymised.com](mailto:buehner@anonymised.com..)
On Wed, Dec 7, 2016 at 5:12 PM, <Thomas-Maximilian.Cuerten@anonymised.com>
wrote:
Hi Nils,
finally works!
documentation?
The chance is proportional to how much you're willing to put it there
(everybody can contribute docs) :wink:
See here:
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
