[Geoserver-users] Address already in use 8080 . problem with external GWC
yesterday I deployed GWC 1.2.6 in tomcat6 on ubuntu 10.04 along side geoserver 2.1.2. It was working ok, but I restarted tomcat6 today and the system is now broken.
Catalina.out is complaining…
“couldn’t flush user prefs java.util.prefs.backingstoreexception couldn’t get file lock.”
Is this a conflict between geowebcache and geoserver? do they both use 8080?..if so, can I just change the gwc port?
thanks,
Rob
----- Weitergeleitete Message -----
Von: Robert Buckley robertdbuckley@anonymised.com
An: Robert Buckley robertdbuckley@anonymised.com
Gesendet: 15:02 Dienstag, 31.Januar 2012
Betreff: Re: [Geoserver-users] Address already in use 8080 . problem with external GWC
sorry…
the last log entries
geoserver:
  • GEOSERVER_DATA_DIR: /home/geoadmin1/data
2012-01-31 14:55:40,543 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“ETRS89 / UTM zone 32N”,GEOGCS[“ETRS89”,DATUM[“European_Terrestrial_Reference_System_1989”,SPHEROID[“GRS 1980”,6378137,298.257222101,AUTHORITY[“EPSG”,“7019”]],AUTHORITY[“EPSG”,“6258”]],PRIME$
2012-01-31 14:55:42,103 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
2012-01-31 14:55:43,857 WARN [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: topotest
2012-01-31 14:55:44,775 WARN [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: dgm
2012-01-31 14:55:45,161 WARN [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: rrop08_mosaic
2012-01-31 14:55:46,137 WARN [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: tk25
2012-01-31 14:55:46,635 WARN [imagemosaic.catalog] - BBOXFilterExtractor::extractBasicProperties(): passed typename is null, using: tk50
2012-01-31 14:55:59,509 WARN [servlet.BaseMapServlet] - Cannot delete file:/var/lib/tomcat6/work/Catalina/localhost/geoserver/wicket-filestore
catalina.2012-01-31.log
31.01.2012 00:00:28 java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
WARNUNG: Could not lock User prefs. Unix error code 2.
An:geoserver-users@anonymised.comsourceforge.netgeoserver-users@lists.sourceforge.net
Gesendet: 14:56 Dienstag, 31.Januar 2012
Betreff: [Geoserver-users] Address already in use 8080 . problem with external GWC
thanks,
Rob
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
Geoserver-users mailing list
Geoserver-users@anonymised.coms.sourceforge.net
more from catalina
Address already in use :8080 ???
31.01.2012 15:29:57 org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
SCHWERWIEGEND: Error initializing endpoint
java.net.BindException: Address already in use :8080
at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:549)
at org.apache.coyote.http11.Http11Protocol.init(Http11Protocol.java:176)
at org.apache.catalina.connector.Connector.initialize(Connector.java:1007)
at org.apache.catalina.core.StandardService.initialize(StandardService.java:677)
at org.apache.catalina.core.StandardServer.initialize(StandardServer.java:795)
at org.apache.catalina.startup.Catalina.load(Catalina.java:540)
at org.apache.catalina.startup.Catalina.load(Catalina.java:560)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:261)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
Caused by: java.net.BindException: Address already in use
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:353)
at java.net.ServerSocket.bind(ServerSocket.java:336)
at java.net.ServerSocket.(ServerSocket.java:202)
at java.net.ServerSocket.(ServerSocket.java:158)
at org.apache.tomcat.util.net.DefaultServerSocketFactory.createSocket(DefaultServerSocketFactory.java:50)
at org.apache.tomcat.util.net.JIoEndpoint.init(JIoEndpoint.java:538)
… 12 more
31.01.2012 15:29:57 org.apache.catalina.startup.Catalina load
SCHWERWIEGEND: Catalina.start
LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use :8080
at org.apache.catalina.connector.Connector.initialize(Connector.java:1009)
INFO: Initialization processed in 812 ms
An:geoserver-users@anonymised.comeforge.netgeoserver-users@lists.sourceforge.net
Betreff: [Geoserver-users] WG: Address already in use 8080 . problem with external GWC
sorry…
geoserver:
thanks,
Rob
Geoserver-users@anonymised.comrceforge.net
On Tue, Jan 31, 2012 at 10:56 AM, Robert Buckley
The only reason I know of having an adresss already in use error is
that the servlet container is in fact trying to open a server port
that's already in use.
When you "restarted" tomcat, did you check it actually shut down? I've
seen broken tomcat installations where the script in /etc/init.d
doesn't actually shut it down. Not sure why though.
Shutdown tomcat and enter
ps -ef | grep java
if you see a running java process and the output contains "catalina", notice the process id and execute
kill -9 <processid>
check again with
ps -ef | grep java
The process should have disappeared, you killed tomcat.
Now start tomcat.
Christian
Zitat von Robert Buckley <robertdbuckley@anonymised.com>:
more from catalina
Address already in use <null>:8080 ???
java.net.BindException: Address already in use <null>:8080
at java.net.ServerSocket.<init>(ServerSocket.java:202)
at java.net.ServerSocket.<init>(ServerSocket.java:158)
... 12 more
LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use <null>:8080
Von: Robert Buckley <robertdbuckley@anonymised.com>
An: "geoserver-users@lists.sourceforge.net" <geoserver-users@lists.sourceforge.net>
An: Robert Buckley <robertdbuckley@anonymised.com>
sorry..
geoserver:
- GEOSERVER_DATA_DIR: /home/geoadmin1/data
PROJCS["ETRS89 / UTM zone 32N",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6258"]],PRIME$
Catalina.out is complaining....
"couldn't flush user prefs java.util.prefs.backingstoreexception couldn't get file lock."
thanks,
Rob
This message was sent using IMP, the Internet Messaging Program.
tomcat6 status was infact “not running”
The last thing I did was try to create an imagemosaic.
now I just get
502 Bad Gatewaywhen trying to get to tomcat manager on http://maps.zgb.de:8080
yours,
Rob
Von: Gabriel Roldan <groldan@anonymised.com.>
Cc:geoserver-users@lists.sourceforge.netgeoserver-users@lists.sourceforge.net
Gesendet: 15:49 Dienstag, 31.Januar 2012
that’s already in use.
When you “restarted” tomcat, did you check it actually shut down? I’ve
doesn’t actually shut it down. Not sure why though.
sudo ps -ef | grep java
1003 5548 5490 0 16:09 pts/1 00:00:00 grep --color=auto java
it wasn´t running…when I start tomcat again it´s the same problem
cheers,
Rob
Von:christian.mueller@anonymised.comchristian.mueller@anonymised.com
Cc:geoserver-users@anonymised.comforge.netgeoserver-users@lists.sourceforge.net
Gesendet: 15:55 Dienstag, 31.Januar 2012
Betreff: Re: [Geoserver-users] WG: Address already in use 8080 . problem with external GWC
ps -ef | grep java
if you see a running java process and the output contains “catalina”, notice the process id and execute
kill -9
check again with
ps -ef | grep java
Now start tomcat.
Christian
more from catalina
… 12 more
Von: Robert Buckley <robertdbuckley@anonymised.com.54…>
An: “geoserver-users@lists.sourceforge.net” <geoserver-users@lists.sourceforge.net>
sorry…
geoserver:
thanks,
Rob
the last logs show the same 8080 in use
31.01.2012 16:10:19 org.apache.coyote.http11.Http11Protocol init
… 12 more
31.01.2012 16:10:19 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 806 ms
31.01.2012 16:10:19 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
31.01.2012 16:10:19 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.24
31.01.2012 16:10:19 org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor host-manager.xml
31.01.2012 16:10:20 org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor manager.xml
INFO: Deploying configuration descriptor examples.xml
INFO: Deploying configuration descriptor docs.xml
INFO: Deploying configuration descriptor ROOT.xml
31.01.2012 16:10:20 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive deegree.war
31.01.2012 16:10:21 org.apache.catalina.core.StandardContext addApplicationListener
INFO: The listener “com.sun.faces.config.ConfigureListener” is already configured for this context. The duplicate definition has been ignored.
31.01.2012 16:10:21 com.sun.faces.config.ConfigureListener contextInitialized
INFO: Mojarra 2.0.2 (FCS b10) für Kontext ‘/deegree’ wird initialisiert.
31.01.2012 16:10:25 com.sun.faces.config.ConfigureListener$WebConfigResourceMonitor$Monitor
INFO: Monitoring jndi:/localhost/deegree/WEB-INF/faces-config.xml for modifications
31.01.2012 16:10:27 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive geonetwork.war
31.01.2012 16:10:27 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/var/lib/tomcat6/webapps/geonetwork/WEB-INF/lib/servlet-api-2.5-6.1.14.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
31.01.2012 16:10:36 org.geotools.referencing.factory.epsg.ThreadedHsqlEpsgFactory createBackingStore
INFO: Creating cached EPSG database version 7.4.0. This operation may take a few minutes…
31.01.2012 16:10:38 java.util.prefs.FileSystemPreferences$2 run
WARNUNG: Couldn’t create user preferences directory. User preferences are unusable.
WARNUNG: java.io.IOException: No such file or directory
31.01.2012 16:10:42 org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive catalogueManager.war
31.01.2012 16:10:42 org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory lws
INFO: Deploying web application directory geoserver
31.01.2012 16:10:43 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/var/lib/tomcat6/webapps/geoserver/WEB-INF/lib/servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
31.01.2012 16:10:43 it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNUNG: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
31.01.2012 16:11:08 org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory viewport
INFO: Deploying web application directory landwirtschaft
31.01.2012 16:11:08 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/var/lib/tomcat6/webapps/landwirtschaft/WEB-INF/lib/servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
31.01.2012 16:11:09 java.util.prefs.FileSystemPreferences checkLockFile0ErrorCode
31.01.2012 16:11:10 java.util.prefs.FileSystemPreferences syncWorld
WARNUNG: Couldn’t flush user prefs: java.util.prefs.BackingStoreException: Couldn’t get file lock.
31.01.2012 16:11:10 org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory ertragspotenzial
INFO: Deploying web application directory geoexplorer
31.01.2012 16:11:11 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/var/lib/tomcat6/webapps/geoexplorer/WEB-INF/lib/servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
31.01.2012 16:11:12 org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory geowebcache
31.01.2012 16:11:39 java.util.prefs.FileSystemPreferences checkLockFile0ErrorCod
An:geoserver-users@lists.sourceforge.netgeoserver-users@anonymised.come.net
Gesendet: 16:11 Dienstag, 31.Januar 2012
cheers,
Rob
ps -ef | grep java
kill -9
check again with
ps -ef | grep java
Now start tomcat.
Christian
more from catalina
… 12 more
An: “geoserver-users@lists.sourceforge.net” <geoserver-users@anonymised.coms.sourceforge.net>
sorry…
geoserver:
An: “geoserver-users@anonymised.coms.sourceforge.net” <geoserver-users@lists.sourceforge.net>
thanks,
Rob
there was a geowebcache.xml in the data/gwc I removed it and it worked again!
yours,
Rob
An:geoserver-users@lists.sourceforge.netgeoserver-users@lists.sourceforge.net
Gesendet: 16:15 Dienstag, 31.Januar 2012
… 12 more
An:geoserver-users@lists.sourceforge.netgeoserver-users@anonymised.com.net
cheers,
Rob
ps -ef | grep java
kill -9
check again with
ps -ef | grep java
Now start tomcat.
Christian
more from catalina
… 12 more
sorry…
geoserver:
thanks,
Rob
You need to change the port in your tomcat`s server.xml. Its better to deploy both Geoserver and GWC inside the same web container
On Tue, Jan 31, 2012 at 6:56 PM, Robert Buckley <robertdbuckley@anonymised.com4…> wrote:
thanks,
Rob
I.R
An: Imran Rajjad rajjad@anonymised.com
Gesendet: 16:44 Dienstag, 31.Januar 2012
Thanks…would you be able to show me an example which should work?
I am not too fond of hacking these important config files!
cheers,
Rob
Von: Imran Rajjad rajjad@anonymised.com
Cc:geoserver-users@lists.sourceforge.netgeoserver-users@anonymised.comnet
Gesendet: 16:33 Dienstag, 31.Januar 2012
On Tue, Jan 31, 2012 at 6:56 PM, Robert Buckley <robertdbuckley@anonymised.com> wrote:
thanks,
Rob
I.R
