[Geoserver-users] Adjust search area to symbol size in GetFeatureInfo of external graphics
in the GetFeatureInfo is a layer displayed with external graphics as
symbols. But the symbols are larger than the search area. So when you click
on the external area of the symbol, you don't get the GetFeatureInfo. Only
clicking in the center works.
How can I extend the area to the edge of the symbol, so the whole symbol is
clickable?
Searching for solutions in this forum wasn't succesful. I already tried
these posts, but couldn't get a clue.
http://osgeo-org.1560.x6.nabble.com/How-to-adjust-the-tolerance-of-FeatureInfo-requests-td3812078.html#a3812080
http://osgeo-org.1560.x6.nabble.com/SLD-point-symbology-offset-via-svg-or-SLD-function-getFeatureInfo-search-area-does-not-follow-td5064319.html
Also the User Manual didn't help me to come to a conclusion, because it
seems that the buffer function doesn't work with external graphics.
Automatic buffer sizing cannot be computed if:
the SLD contains sizes that are specified as feature attribute values
the SLD contains external graphics and does not specify their size
explicitly
Does anyone knows a solution or has a clue on this issue?
I would be very greatful for any hint.
Best Regards,
Benjamin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adjust-search-area-to-symbol-size-in-GetFeatureInfo-of-external-graphics-tp5134057.html
