Hello
I'm new to geoserver so i can't figure out how to do this.
I've installed geoserver 2.5.1 as a service on Window. Trying to increase
memory and i have found this
http://docs.geoserver.org/stable/en/user/production/container.html but
can't figure out how should i do this.
Also how can i check if the configuration is done.
Thanks for your help, Dimmerthe.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Allocating-extra-memory-to-server-tp5145365.html
Dimmerthe,
If you used the Windows installer, you make the changes to increase the
memory in the GEOSERVER_HOME/wrapper/wrapper.conf file. After the changes,
you should be able to see the additional memory allocated in the resource
monitor.
Hope this helps.
Jerome
-----Original Message-----
From: Dimmerthe [mailto:awdawdqseqse123@anonymised.com]
Sent: Wednesday, June 11, 2014 3:16 PM
Subject: [Geoserver-users] Allocating extra memory to server.
Hello
365.html
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems Open Source. Fast.
Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Thank you for help. It solved my problem.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Allocating-extra-memory-to-server-tp5145365p5145370.html
