it wasn't working, but based on some code of Simone I created the
following patch/pull request which made it working with me:
https://github.com/geoserver/geoserver/pull/595
I have to write a test first to make it pullable and land in current
dev/master branch.
That is on my todo list
If you are able to build geoserver yourself (actually pretty easy, this
was the first time for me too), you can pull that PR in and try.
Richard Duivenvoorde
On 13-06-14 08:24, Balázs Eigner wrote:
Hi all!
I'm relatively new to the animation reflector of GeoServer and tried to
create a transparent GIF loop whitout any luck. The opaque version works
well and currently stuck with this using a white background. Are there
any workaround or way to hack the transparency support into GeoServer to
get a transparent background animation or is it planned to be intruduced
in a (not so distant) future version? (Currently I use 2.4.0 which is
not the most up-to-date one, so if in newer ones it's fixed, than sorry
for the question.)
Best Regards,
Balazs Eigner
2014-05-15 14:15 GMT+02:00 Richard Duivenvoorde <rdmailings@anonymised.com
<mailto:rdmailings@anonymised.com>>:
does anybody here know if transparency should work with animated gif
output on WMS requests (in combi with time or elevation)?
I'm able to receive animated gif's but they always have a background,
whatever combi of transparent/bgcolor I try.
I've tried to look into source code of geoserver, but there is a lot of
advanced imaging stuff there, of which I'm not sure which code is
reached and which not. I found some lines from which I conclude that it
should be possible:
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/map/GIFMapResponse.java#L95
any help or hints are appreciated
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform
available
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
<mailto:Geoserver-users@lists.sourceforge.net>
