Bruce,
your two references to the property name gwml2wc:bHoleDateOfDrilling differ in the case of "h" in "Hole". XML names are case sensitive.
In the mapping file you have:
<targetAttribute>gwml2wc:bholeDateOfDrilling</targetAttribute>
with a lowercase "h" but the reported property name is:
http://www.opengis.net/gwml-wellconstruction/2.1#bHoleDateOfDrilling
with an uppercase "H".
The capitalisation of "bHoleDateOfDrilling" seems inconsistent with other property names; you might like to check the schema and report back to the schema maintainer.
Please either change your mapping file to use "<targetAttribute>gwml2wc:bHoleDateOfDrilling</targetAttribute>" or change the property name in the schema to "bholeDateOfDrilling".
Your sourceExpression is fine as bare postgis column names are mapped to lowercase and are thus case insensitive.
Kind regards,
Ben.
On 27/11/15 16:11, Bruce.Simons@anonymised.com wrote:
GroundWaterML2 services that were running in August are now giving errors.
In this error the response suggests that gwml2wc:bholeDateOfDrilling is not a valid path, but then it is listed as one of the valid paths:
java.lang.RuntimeException: Error applying mapping with targetAttribute gwml2wc:bholeDateOfDrilling
gwml2wc:bholeDateOfDrilling is not a valid location path for type http://www.opengis.net/gwml-wellconstruction/2.1:BoreholeType.
gwml2wc:bholeDateOfDrilling ns: http://www.opengis.net/gwml-wellconstruction/2.1,
BoreholeType properties:
... <snip>
http://www.opengis.net/gwml-wellconstruction/2.1#bholeCoreInterval,
http://www.opengis.net/gwml-wellconstruction/2.1#bHoleDateOfDrilling,
http://www.opengis.net/gwml-wellconstruction/2.1#bholeDriller,
... <snip>
The datatype in the PostGres database is "date".
The Attribute mapping in the configuration file is:
<AttributeMapping>
<sourceExpression>
<OCQL>bholedateofdrilling</OCQL>
</sourceExpression>
</AttributeMapping>
Removing this from the configuration file returns a WFS response without errors.
This GeoServer instance is running version 2.6.2
Bruce Simons
Information Modeller
CSIRO Land and Water/ Environmental Information Infrastructures
E: bruce.simons@anonymised.com<mailto:bruce.simons@anonymised.com> T: +61 3 9252 6514 M: +61 475 954 391
PO Box 56, Highett, Victoria, 3190
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
