[Geoserver-users] app-schema - shows different behavior on c: and d:
Hello, Gabriel
I have had the same problem. You can watche the log file and see the error message(illegal characters in the path). If it's the same bug, all spaces in the path are wrong and you must install Geoserver on the C:\ root or install the last nigthly build where the bug is fixed.
Dorian
----- Message Original -----
De: Carlos Gabriel Asato <g_asato2000@anonymised.com>
Envoyé: Mar, 1/9/2009 18:33
À: Gabriel Roldan <groldan@anonymised.com>
Cc: geoserver-users <geoserver-users@lists.sourceforge.net>
Sujet: Re: [Geoserver-users] app-schema - shows different behavior on c: and d:
Dear Gabriel
I am not using spaces in between my paths (gs_data_dir and other internal variables paths). But thinking what could be happened the only path that has spaces is my systems are where tomcat and geoserver are located:
c:/Program Files (x86)/Apache Software Fundation/Tomcat 6.0/webapps/geoserver
I am already sent you my gsml eziped directory to your private e-mail
Thank you very for your help much Gabriel
Gabriel Asato
Unidad Sensores Remotos y SIG
Servicio Geológico Minero Argentino
(SEGEMAR)
Av. Julio A. Roca 651 p 8 of 1
Cdad. Autónoma de Buenos Aires
ARGENTINA
tel 54-11-4349-3158/26
fax 54-11-4349-3287
De: Gabriel Roldan <groldan@anonymised.com>
Para: Carlos Gabriel Asato <g_asato2000@anonymised.com>
CC: geoserver-users <geoserver-users@lists.sourceforge.net>
Enviado: martes 1 de septiembre de 2009, 13:09:03
Asunto: Re: [Geoserver-users] app-schema - shows different behavior on c: and d:
Hi Gabriel,
does any of the paths for c: or d: have spaces in between? (like in c:\datos de prueba\geoserver or whatever)
I think the app-schema team just fixed a bug related to that.
What are you using as your data source? if shapefiles or any other file
based source could you send me your data directory so I can give it a try and see what's going on? (preferably zippped through private email, the list won't accept the attachment I guess).
Gabriel
Carlos Gabriel Asato wrote:
Dear all
I am still having the same problem when I tried to run my geoserver app-schema extension.
What I tried was the following
I made all test on a Windows XP 64. Geoserver is installed in disk c: and geoserver data is installed in disk d:
I installed geoserver 2 rc1 war file.
I installed for this version GML and app-schema extensions ( geoserver beta 2 needs only app-schema extension ).
I created by hand gsml workspace in disk c: and either in disk d: I and copied the files and data sutrcutre from Auscope repository.
geoserver showns both datastores (GeologicUnit and
MappedFeature) when a wfs GetCapabilities was performed.
But when GetFeatures was performed error messages apeared.
Curiously when I tried to create the gsml workspace in c: and in d: geoserver I received different error messages.
http://localhost:8080/geoserver/wfs?request=GetFeature&typename=gsml:GeologicUnit&maxfeatures=2&version=1.1.0&OUTPUTFORMAT=GML3
When I put the gsml
workspace in disk c: this appeadared
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Error occurred getting features null null</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
When I put the gsml workspace in disk d: a more complex error message appeared.
<ows:ExceptionText>
Feature type GeologicUnit does not exist. This datastore only has gsml_GeologicUnit
<ows:ExceptionText>Details:</ows:ExceptionText>
<ows:ExceptionText>
org.geoserver.wfs.WFSException: Error occurred getting features
    at org.geoserver.wfs.GetFeature.run(GetFeature.java:397)
    at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:115)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
    at
org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
    at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
    at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
    at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
    at $Proxy19.getFeature(Unknown Source)
Source)
    at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
    at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:574)
    at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
    at
The only idea I have now is try to perform this configuration task again but on linux. Any other idea?
Thanks
in advance for your help
Gabriel Asato
(SEGEMAR)
ARGENTINA
fax 54-11-4349-3287
Encontra las mejores recetas con Yahoo! Cocina.
http://ar.mujer.yahoo.com/cocina/
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best,
core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-users mailing list
-- Gabriel Roldan
OpenGeo - http://opengeo.org
http://ar.mujer.yahoo.com/cocina/------------------------------------------------------------------------------
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july_______________________________________________
