[Geoserver-users] ArcSDE working in 1.6RC2
Hmm, after adding this I can't create a featuretype anymore on SDE, this did
work before the change:
The following exception was thrown:
java.lang.NoSuchFieldError: org.geotools.filter.Filter: field NONE not found
Or:
java.lang.NullPointerException
15 Jan 16:41:17 WARN [org.vfny.geoserver.global] - Suppressing StdOut
logging. If you want to see GeoServer logs, be sure to look in
'/var/tomcat/webapps/geoserver/data/logs/geoserver.log'
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
15 Jan 16:41:21 WARN [org.vfny.geoserver.global] - Suppressing StdOut
Jan 15, 2008 4:41:39 PM org.geotools.data.arcsde.ConnectionConfig
checkParams
WARNING: No database name specified
checkParams
Jan 15, 2008 4:41:48 PM org.geotools.data.arcsde.ArcSDEAdapter
createAttributeTypes
WARNING: Figured Row-ID Column named 'OBJECTID' for table TOPOGRAFIE.DTB_VLK
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Andrea Aime <aaime@anonymised.com>
Naar: Bart van den Eijnden OSGIS <bartvde@anonymised.com>
Onderwerp: Re: [Geoserver-users] ArcSDE working in 1.6RC2
Datum: 15/01/08 13:20
Bart van den Eijnden (OSGIS) ha scritto:
&gt; Hi list,
&gt;
&gt; I am trying 1.6RC2 against ArcSDE (9.1 libs), but I can't get it to
work.
&gt; Does this ring a bell for anyone? TIA.
http://jira.codehaus.org/browse/GEOS-1648
I believe you can fix it by downloading jsqlparser from here:
http://lists.refractions.net/m2/jsqlparser/jsqlparser/0.3.14/jsqlparser-0.3.14.jar
and adding it into web-inf/lib.
