[Geoserver-users] authenticating with basic auth
Hi
Please stay on the mailing list.
POST or PUT has no influence on the authentication protocol, using username and password as URL parameters is a bad practice and not supported officially.
  1. Add a new role TEST_ROLE to geoserver and add a new user TEST_USER
  2. protect the read access to the resource topp:city, users must have the role TEST_ROLE
  3. Open your browser and enter
http://mydomain/geoserver/wms?bbox=34.875,-62.5,32.3125,-55.5&Format=image/png&request=GetMap&layers=topp:city&width=250&height=250&srs=EPSG:4321
A login window must occur
4) Since you did not attach the TEST_ROLE to the TEST_USER, access denied is the answer.
Using PHP, look here for the code snippet
http://php.net/manual/en/features.http-auth.php
Now, add the role TEST_ROLE to the TEST_USER.
Close the browser, open it and retry. Things should work.
Christian
On Thu, Oct 30, 2014 at 10:46 PM, <boliwe@anonymised.com> wrote:
You have answered a mail here: http://osgeo-org.1560.x6.nabble.com/authenticating-with-basic-auth-td5035587.html
(Call the services directly and add the “Authorization” header for EACH request. Geoserver does not create a session.)
I have same problem. I could not understand add “Authorization”.
I tried send request from browser like following but not worked.
http://mydomain/geoserver/wms?bbox=34.875,-62.5,32.3125,-55.5&Format=image/png&request=GetMap&layers=topp:city&width=250&height=250&srs=EPSG:4321&username=u1&password=p1
I created a PHP script and send POST request but did not worked.
Sent from http://osgeo-org.1560.x6.nabble.com
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
