[Geoserver-users] Authkey community plugin - multiple geoserver instances
Hi community,
*Problem:* When creating a new authentication key using the Key
authentication module
<http://docs.geoserver.org/stable/en/user/community/authkey/index.html&gt;
the authentication process fails with Geoserver returning a 403 unless I
restart all instances of Geoserver.
*Background:* My setup is the following: Database VM (Linux Ubuntu 16.04,
and PostgreSQL 9.6), Geoserver VM (Linux Ubuntu 16.04, 4 instances of x
apache-tomcat-7.0.73, instances of 4 x Geoserver 2.10.1, All Geoserver
instances have installed the following Geoserver extensions: Monitor and
INSPIRE, and the following community module: Key authentication module)
After adding the new authentication key I reload configuration to the slave
Geoservers and attempt to get data. The error is 403. Having failed I
restarted all Geoserver instances and the authentication was successful. I
have replicated this multiple times.
Is this typical behaviour for that module?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Authkey-community-plugin-multiple-geoserver-instances-tp5311236.html
