Justin Deoliveira ha scritto:
Hi Giambattista,
I have the confirmed the problem. At first glance it seemed trivial to fix but after thinking a bit more about it I think there is an issue here.
If a client makes a wfs 1.1 request specifying GML2, then the schema location for the wfs schema has to be the 1.0 version of the schema (WFS-basic.xsd). The reason being that if the 1.1 version of the schema is used (wfs.xsd), i dont believe the document would validate, because the wfs 1.1 schema references gml3, not gml2. And gml3 is not backwards compatable with gml2.
The same applies to the describe feature type request. If a 1.1 feature type request get sent back to the server, it will return the wfs 1.1 schema which against references gml3.. and I believe there will be a conflict.
You have stumbled onto a tricky issue here. I would like to hear other developers thoughts... and maybe ask wfs-dev, as this seems to be an inconsistency with the spec?
Hum, the spec does not support GML2 output in any way, it's just our
custom addition. The way you describe it, it seems that we either
accept this weird output, or we remove GML2 output from WFS 1.1
right away, since as you say any attempt to output GML2 with the
WFS 1.1 schemas in the mix will result in an inconsistent document.
Giambattista, out of curiosity, is there any specific reason you're
using WFS 1.1? If it's reprojection, we have a custom extension
for WFS 1.0 that allows reprojection to be used in 1.0 as well,
at least in GetFeature GET requests (not sure about XML POST ones,
I would have to check).
Also, beware that by using WFS 1.1 you'll receive back geographic
coordinates in lat/lon order instead of the usual lon/lat used
by most GIS systems (that's by spec, see
http://geoserver.org/display/GEOSDOC/2.+WFS for more details)
