On Wed, Jun 1, 2011 at 6:06 AM, Harikumar Reddy <harik.gis@anonymised.com> wrote:
I have deleted the default layers like below. We need to have write access
for the geoserver data directory.
First removed configured layers
Then removed datastores
Then removed styles
Then removed workspaces
Error may occurs, if we tried to delete the datastores or workspaces without
removing layers, which are referencing the datastores/workspaces.
Permissions also a reason sometimes.
Permission is definitely the reason. All you have to do to fully
cleanup a data directory
is to select all the workspaces and delete them, this will trigger a
cascaded delete
of everything contained in the workspaces.
And then you can delete the styles, all but the four built in ones,
that indeed cannot
be deleted (the error you're seeing is due to a missing
internationalitazion string,
just fixed it).
Just tried it, select all workspaces, delete, select all styles,
delete, and you're left
with a server without any data or style configured (besides the 4 built-in basic
styles). You can delete the styles or the workspaces in whatever order, if you
remove the styles first all the layers will be reassigned to a built-in style
depending on their geometric type.
Hari.
On Wed, Jun 1, 2011 at 2:34 AM, Jeff Dege <jeff.dege@anonymised.com> wrote:
In a new install of 2.1.0, I’m removing all of the default layers, styles,
etc.
When I try to remove one of the non-removable styles (line, point,
polygon, raster), instead of getting an error message telling me I can’t, I
get:
Oops, something went wrong...
Sorry, something unexpected happened on the server.
Here's an error report you can include in a JIRA bug report about this
issue:
org.apache.wicket.WicketRuntimeException: Property
'ConfirmRemovalPanel.notRemovedObject' not found in property files. Markup:
[markup =
jar:file:/var/lib/tomcat6/webapps/geoserver-2.1.0/WEB-INF/lib/web-core-2.1.0.jar!/org/geoserver/web/data/ConfirmRemovalPanel.html
<html> <body> <wicket:panel> <div wicket:id="rootObjects"> <h3>
<wicket:message key="ConfirmRemovalPanel.aboutRemove">About to
remove</wicket:message>: <span wicket:id="rootObjectNames"></span> </h3>
</div> <div wicket:id="notRemovedObjects"> <wicket:message
key="ConfirmRemovalPanel.notRemovedObject">The following objects could not
be removed:</wicket:message> <ul class="plain-ul"> <li
wicket:id="notRemovedList"><span wicket:id="name"></span>: <span
wicket:id="reason"></span></li> </ul> </div> <div
wicket:id="removedObjects"> <wicket:message
key="ConfirmRemovalPanel.removedObjects">The following objects will be
removed</wicket:message>: <ul class="plain-ul"> <li
wicket:id="workspacesRemoved"><wicket:message
key="ConfirmRemovalPanel.workspaces"/>: <span
wicket:id="workspaces"></span></li> <li wicket:id="storesRemoved"
class="plain-li"><wicket:message key="ConfirmRemovalPanel.stores"/>: <span
wicket:id="stores"></span></li> <li
wicket:id="layersRemoved"><wicket:message
key="ConfirmRemovalPanel.layers"/>: <span wicket:id="layers"></span></li>
<li wicket:id="groupsRemoved"><wicket:message
key="ConfirmRemovalPanel.groups"/>: <span wicket:id="groups"></span></li>
</ul> </div> <div wicket:id="modifiedObjects"> <wicket:message
key="ConfirmRemovalPanel.modifiedObjects">The following objects will be
modified as a result</wicket:message>: <ul class="plain-ul"> <li
wicket:id="layersModified"><wicket:message
<li wicket:id="groupsModified"><wicket:message
</ul> </div> </wicket:panel> </body> </html>, index = 18, current = [Raw
markup]] at
org.apache.wicket.markup.resolver.WicketMessageResolver$MessageContainer.onComponentTagBody(WicketMessageResolver.java:217)
at org.apache.wicket.Component.renderComponent(Component.java:2686) at
org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1538) at
org.apache.wicket.Component.render(Component.java:2517) at
org.apache.wicket.MarkupContainer.autoAdd(MarkupContainer.java:229) at
org.apache.wicket.markup.resolver.WicketMessageResolver.resolve(WicketMessageResolver.java:148)
at
org.apache.wicket.markup.resolver.ComponentResolvers.resolve(ComponentResolvers.java:81)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1444)
at
org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1603)
at
org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1527)
org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1440) at
at
org.apache.wicket.MarkupContainer.renderAssociatedMarkup(MarkupContainer.java:696)
at
org.apache.wicket.markup.html.panel.Panel.onComponentTagBody(Panel.java:114)
at
at
org.apache.wicket.markup.html.form.Form.onComponentTagBody(Form.java:1995)
org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1554) at
org.apache.wicket.Page.onRender(Page.java:1575) at
org.apache.wicket.Page.renderPage(Page.java:913) at
org.apache.wicket.request.target.component.PageRequestTarget.respond(PageRequestTarget.java:63)
at
org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at
org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at
org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at
org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at
org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at
org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617) at
javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at
org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at
org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at
at
at
at
org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at
at
at
org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at
at
at
org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at
at
at
org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at
at
at
org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at
at
at
org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at
at
at
org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at
at
at
at
at
at
org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at
org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
at
at
at
at
org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at
at
at
org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
at
at
org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at
at
at
at
org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71) at
at
at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41) at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:662)
Simplify data backup and recovery for your virtual environment with
vRanger.
Installation's a snap, and flexible recovery options mean your data is
safe,
secure and there when you need it. Data protection magic?
Nope - It's vRanger. Get your free trial download today.
http://p.sf.net/sfu/quest-sfdev2dev
Geoserver-users mailing list
Simplify data backup and recovery for your virtual environment with vRanger.
Installation's a snap, and flexible recovery options mean your data is safe,
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
