[Geoserver-users] BUG: Rendering fails when labels are used
Hello,
This is my first post to geoserver users list, so I hope that this is right way how to report bug.
GeoServer Version 2.20.1 (Java Rendering Engine: sun.java2d.pisces.PiscesRenderingEngine)
  • If I set the SLD style with any label to line layer, then some tiles gives this rendering fail.
  • If I remove label (TextSymbolizer tag) from style, then every tiles are OK.
SLD style:
1<?xml version="1.0" encoding="UTF-8"?>
2<StyledLayerDescriptor version=“1.0.0”
3 xsi:schemaLocation=“http://www.opengis.net/sld StyledLayerDescriptor.xsd”
4 xmlns=“http://www.opengis.net/sld
5 xmlns:ogc=“http://www.opengis.net/ogc
6 xmlns:xlink=“http://www.w3.org/1999/xlink
7 xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”>
8
9 default_line
10
11
12
13 100000
14
15
16 #ffff00
17 1
18 bevel
19 square
20
21
22
23
24 ogc:PropertyNamename</ogc:PropertyName>
25
26
27
28
29
30 #000000
31
32
33
34
35
36
37
GeoServer Version 2.15.1 (Java Rendering Engine: sun.java2d.marlin.DMarlinRenderingEngine)
  • no rendering problem in this version
Best regards
Tomas Bernat
Can you turn up logging to DEVELOPER, and send us the relevant part of the log file as text we will also need a small data file to test against.
Ian
Ian Turton
