[Geoserver-users] Bug Report in WPS of GeoServer
I just wrote a simple WPS client with geotools for GeoServer. I used
the same code in the geotools website:
http://docs.geotools.org/latest/userguide/unsupported/wps.html
I got the following error in WPSFactory():
Exception in thread "main" java.lang.NullPointerException
        at org.geotools.data.wps.WPSUtils.getLiteralTypeFromReference(WPSUtils.java:296)
        at org.geotools.data.wps.WPSUtils.createInputParamMap(WPSUtils.java:183)
        at org.geotools.data.wps.WPSFactory.buildValuesFromProcessDescriptionType(WPSFactory.java:81)
        at org.geotools.data.wps.WPSFactory.<init>(WPSFactory.java:68)
        at au.org.aurin.wps.WPSClient.getCapabilities(WPSClient.java:108)
        at au.org.aurin.wps.WPSClient.main(WPSClient.java:42)
After looking into WPSUtiles class I found out that problem is here:
if (literalData != null) {
                String reference = literalData.getDataType().getReference();
                type = getLiteralTypeFromReference(reference);
reference is null, so getLiteralTypeFromReference gives
java.lang.NullPointerException.
I checked the same code with 52N WPS and Deegree WPS, which works fine!
So, I believe that there is a bug in XML of DescribeProcess in
GeoServer as listed below as well:
These are part of XML of Describe process (SimpleBufferAlgorithm in
52N WPS and JTS:buffer in Geoserver WPS)
-------------- in 52N
<LiteralData>
       <ns1:DataType ns1:reference="xs:double"
xmlns:ns1="http://www.opengis.net/ows/1.1&quot;/&gt;
       <ns1:AnyValue xmlns:ns1="http://www.opengis.net/ows/1.1&quot;/&gt;
     </LiteralData>
-------------- in GeoSrrver
<wps:LiteralData>
<ows:DataType>xs:double</ows:DataType>
<ows:AnyValue/>
</wps:LiteralData>
Bahman
On Wed, Aug 17, 2011 at 2:01 AM, Bahman Javadi <bahmanj@anonymised.com> wrote:
<wps:LiteralData>
<ows:AnyValue/>
</wps:LiteralData>
From what I can see you're running an old version of GeoServer,
the issue you're facing should be this one:
http://jira.codehaus.org/browse/GEOS-4521
that has been fixed in 2.1.1 release
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hi Andrea,
Thanks for your reply.
I installed Geoserver 2.1.1 and WPS-plugin 2.1.1 as well. But still I
have the same problem.
Any idea?
Bahman
On Wed, Aug 17, 2011 at 4:51 PM, Andrea Aime
<wps:LiteralData>
<ows:AnyValue/>
</wps:LiteralData>
Ing. Andrea Aime
Tech lead
On Thu, Aug 18, 2011 at 2:55 AM, Bahman Javadi
Hi Andrea,
Any idea?
Is the output of DescribeProcess any different than before?
Do you happen to have a small, self contained java program
using the geotools library to connect to the WPS?
Ing. Andrea Aime
Tech lead
I am not sure about any changes in the WPS of the GeoServer. This is
my first try to work with GeoServer.
I used the same java code in the geotools website:
This client works for 52N and Deegree WPS servers. But has this
problem with GeoServer.
I also checked for other processes. It seems that the problem is with
LiteralData, where ComplexData
is ok. For example for Buffer which has one Double and one Geometry,
we got the error for Double number and Geometry is fine.
Thanks for your consideration.
Bahman
On Thu, Aug 18, 2011 at 6:29 PM, Andrea Aime
Hi Andrea,
Any idea?
Ing. Andrea Aime
Tech lead
Hi
This is my WPS client in java with geotools:
import java.io.ByteArrayInputStream;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.net.MalformedURLException;
import java.net.URL;
import java.util.Iterator;
import java.util.LinkedHashMap;
import java.util.Map;
import java.util.Set;
import java.util.TreeMap;
import net.opengis.wps10.*;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.eclipse.emf.common.util.EList;
import org.geotools.data.wps.WPSFactory;
import org.geotools.data.wps.WebProcessingService;
import org.geotools.data.wps.request.DescribeProcessRequest;
import org.geotools.data.wps.response.DescribeProcessResponse;
import org.geotools.ows.ServiceException;
import org.geotools.process.Process;
import org.geotools.process.ProcessException;
public class WPSClient {
  /** The logger. */
    private static final Log LOGGER = LogFactory.getLog(WPSClient.class);
    static String PR1 = "gt:DoubleAddition";
    static String PR2 = "";
    static String SERVER =
"http://localhost:8080/geoserver/ows?service=wps&version=1.0.0&request=GetCapabilities&quot;;
// static String SERVER =
"http://localhost:8080/wps/WebProcessingService?Request=GetCapabilities&Service=WPS&quot;;
  public static void main(String args){
    System.out.println("WPS Client");
    Map<String, String> r = getCapabilities();
  public String getEndpoint() {
// return this.url + "/" + this.service + "/wps";
    return " ";
  // TODO get this method to work and replace getCapabilities() with this one.
   public static Map<String, String> getCapabilities () {
        //https://www2.landgate.wa.gov.au/ows/wfspublic_4283/wfs?service=wfs&version=1.0.0&request=GetCapabilities
// LOGGER.info("Getting Capabilities from endpoint - " + getEndpoint());
        URL url = null;
    try {
      url = new URL(SERVER);
    } catch (MalformedURLException e1) {
      // TODO Auto-generated catch block
      e1.printStackTrace();
        WebProcessingService wps = null;
    try {
      wps = new WebProcessingService(url);
    } catch (ServiceException e) {
      e.printStackTrace();
    } catch (IOException e) {
        WPSCapabilitiesType capabilities = wps.getCapabilities();
        String wpsCapabilitiesVersion = capabilities.getVersion();
        System.out.println("WPS version: " + wpsCapabilitiesVersion);
        // view a list of processes offered by the server
        ProcessOfferingsType processOfferings =
capabilities.getProcessOfferings();
        EList processes = processOfferings.getProcess();
        System.out.println("Number of Processes:" + processes.size());
        // create a WebProcessingService as shown above, then do a
full describe process on my process
       DescribeProcessRequest descRequest = wps.createDescribeProcessRequest();
      descRequest.setIdentifier(PR1); // describe the double addition
process
// descRequest.setIdentifier("org.n52.wps.server.algorithm.SimpleBufferAlgorithm");
       // send the request and get the ProcessDescriptionType bean to
create a WPSFactory
       DescribeProcessResponse descResponse = null;
    try {
      descResponse = wps.issueRequest(descRequest);
       ProcessDescriptionsType processDesc = descResponse.getProcessDesc();
       ProcessDescriptionType pdt = (ProcessDescriptionType)
processDesc.getProcessDescription().get(0);
       WPSFactory wpsfactory = new WPSFactory(pdt, url);
       // create a process
       Process process = wpsfactory.create();
       System.out.println("Process Descroption: "+ wpsfactory.getDescription());
       // setup the inputs
       Map<String, Object> map = new TreeMap<String, Object>();
       Double d1 = 77.5;
       Double d2 = 22.3;
       map.put("input_a", d1);
       map.put("input_b", d2);
       // you could validate your inputs against what the process
expected by checking
       // your map against the Parameters in wpsfactory.getParameterInfo(), but
       // to keep this simple let's just try sending the request
without validation
       Map<String, Object> results = null;
// ProgressListener
    try {
      results = process.execute(map, null);
    } catch (ProcessException e) {
       Double result = (Double) results.get("result");
       System.out.println(result);
    return null;
Please have a look.
Bahman
On Thu, Aug 18, 2011 at 9:39 PM, Bahman Javadi <bahmanj@anonymised.com> wrote:
Bahman
Hi Andrea,
Any idea?
Ing. Andrea Aime
Tech lead
Get a FREE DOWNLOAD! and learn more about uberSVN rich system,
user administration capabilities and model configuration. Take
the hassle out of deploying and managing Subversion and the
tools developers use with it. http://p.sf.net/sfu/wandisco-d2d-2
Geoserver-devel mailing list
I am trying to document up process stuff; mind if I use your program as a starting example?
Jody Garnett
On Friday, 19 August 2011 at 10:46 AM, Bahman Javadi wrote:
Hi
/** The logger. */
static String PR1 = “gt:DoubleAddition”;
static String PR2 = “”;
http://localhost:8080/geoserver/ows?service=wps&version=1.0.0&request=GetCapabilities”;
http://localhost:8080/wps/WebProcessingService?Request=GetCapabilities&Service=WPS”;
System.out.println(“WPS Client”);
// return this.url + “/” + this.service + “/wps”;
return " ";
URL url = null;
try {
try {
System.out.println(“Number of Processes:” + processes.size());
process
// descRequest.setIdentifier(“org.n52.wps.server.algorithm.SimpleBufferAlgorithm”);
create a WPSFactory
try {
// create a process
// setup the inputs
Double d1 = 77.5;
Double d2 = 22.3;
map.put(“input_a”, d1);
map.put(“input_b”, d2);
// to keep this simple let’s just try sending the request
without validation
// ProgressListener
try {
Double result = (Double) results.get(“result”);
return null;
Please have a look.
Bahman
Bahman
Hi Andrea,
Any idea?
Ing. Andrea Aime
Tech lead
Geoserver-devel@anonymised.comists.sourceforge.net
Sure. Please let me know if you reach to a promising point;
Bahman
On Fri, Aug 19, 2011 at 3:10 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
starting example?
Jody Garnett
Hi
/** The logger. */
return " ";
URL url = null;
try {
try {
process
create a WPSFactory
try {
// create a process
// setup the inputs
Double d1 = 77.5;
Double d2 = 22.3;
without validation
// ProgressListener
try {
return null;
Please have a look.
Bahman
wrote:
Bahman
Hi Andrea,
Any idea?
Ing. Andrea Aime
Tech lead
