[Geoserver-users] Building geoserver from SVN
Hi All,
I just go tthe latest from SVN and mvn:compile fails with the error below.
Tim
Compiling 27 source files to
/Users/tim/dev/projects/geoserver/wfsv/target/classes
[INFO]
[ERROR] BUILD FAILURE
[INFO]
[INFO] Compilation failure
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureStore.java:[17,7]
org.vfny.geoserver.global.GeoServerVersioningFeatureStore is not abstract
and does not override abstract method
getDifferences(java.lang.String,java.lang.String,org.opengis.filter.Filter)
in org.geotools.data.VersioningFeatureSource
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureStore.java:[33,15]
in org.geotools.data.VersioningFeatureSource cannot be applied to
(java.lang.String,java.lang.String,org.opengis.filter.Filter,java.lang.String)
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureStore.java:[38,15]
getLog(java.lang.String,java.lang.String,org.opengis.filter.Filter) in
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureSource.java:[25,7]
org.vfny.geoserver.global.GeoServerVersioningFeatureSource is not abstract
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureSource.java:[36,15]
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureSource.java:[41,15]
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureLocking.java:[25,7]
org.vfny.geoserver.global.GeoServerVersioningFeatureLocking is not
abstract and does not override abstract method
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureLocking.java:[41,15]
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureLocking.java:[46,15]
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/geoserver/wfsv/response/v1_1_0/GetDiffTransactionOutputFormat.java:[138,43]
cannot find symbol
symbol : method getChangedAttributes()
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/geoserver/wfsv/RollbackElementHandler.java:[109,27]
(<nulltype>,java.lang.String,org.opengis.filter.Filter,java.lang.String)
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/geoserver/wfsv/GetDiff.java:[144,53]
(java.lang.String,java.lang.String,org.opengis.filter.Filter,<nulltype>)
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/geoserver/wfsv/GetLog.java:[148,46]
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/geoserver/wfsv/response/v1_1_0/FeatureDiffCollection.java:[33,49]
cannot find symbol
symbol : constructor
FeatureDiffReader(org.geotools.data.postgis.FeatureDiffReader)
location: class org.geotools.data.postgis.FeatureDiffReader
/Users/tim/dev/projects/geoserver/wfsv/src/main/java/org/geoserver/wfsv/response/v1_1_0/FeatureDiffCollection.java:[44,20]
cannot find symbol
Ignore that - I was using the wrong SVN trunk
1.5.x works fine
Hi All,
Tim
[INFO]
[INFO]
cannot find symbol
cannot find symbol
cannot find symbol
Geoserver-users mailing list
