I have used the web archive file geoserver.war (tried both versions 2.13.0 and 2.12.2) to run the webapp under Tomcat 9.0 on Windows 10. I can access the splash page for geoserver from my Firefox browser window, but the default userid (admin) and password (geoserver) do not work. I keep getting the message “Invalid username/password combination.” I tried editing the file users.xml to (in directory webapps/geoserver/security/usergroup/default) put the password in plain text, but that does not work either.
Note that I changed the default port for the Tomcat to be 1025 instead of 8080 because of a Windows conflict with Skype.
I can’t say I’ve seen this – although not tried with Tomcat 9. Can you try it with Tomcat 8 or 8.5?
Do you have any other authentication modules (e.g. geofence) loaded?
Brad
Thanks, Brad. I just tried it with tomcat 8.5…same behavior. Java is version 8 build 161, which is passing the install filters. Machine is Win 10.Pro X64 bit version. 24 GB of Ram, so that can’t be it. Likewise terabyte SSD as main drive, so shouldn’t be problems there. We manually move the <*.war> file into the <tomcat/webapps> directory, where it is successfully recognized by the JVM resulting in the automatic creation of the directory containing the data space.
I’m unfamiliar with . Will it do anything useful if I can’t get by the login for geoserver?
Bill
Brad
Hi
Did you add the plain text password with the proper prefix plain: like so
plain:mypassword
On Mon, Mar 26, 2018 at 9:35 AM, William Graves <graveswr@anonymised.com> wrote:
Bill
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Brad
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Christian,
We did make the following substitution for test purposes: no joy.
For the file: <…/webapps>geoserver>data>security>usergroup>default>users.xml
—>Content:
we substituted:
So we tried. Did we get the plain: in the wrong place or something?
From the Tomcat manager, after a couple of attempts, we could stop the geoserver, but it was more difficult (i.e., took a few tries) before it would restart again.
Bill
On Mon, Mar 26, 2018 at 1:36 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi
plain:mypassword
Bill
Geoserver-users@anonymised.comrge.net
Brad
Hi
is correct.
Do you see some java stack trace in catalina.out when you try to login ?
On Mon, Mar 26, 2018 at 11:20 AM, William Graves <graveswr@anonymised.com> wrote:
Hi Christian,
—>Content:
we substituted:
Bill
On Mon, Mar 26, 2018 at 1:36 AM, Christian Mueller <christian.mueller@anonymised.com.5602…solutions.at> wrote:
Hi
plain:mypassword
Bill
Brad
The geofence module is a complicating factor if you had it installed. Not a consideration in this case if you don’t have it installed.
Do you see anything relevant (messages, exceptions) in the tomcat or geoserver logs?
Brad
So, I wanted to thank everyone who helped. I finally got GeoServer to boot using the following formula:
Do the direct install…the one based upon an <*.exe> file. Be sure you are administrator. Do this on top of Windows 10 without TomCat. I will try to get the TomCat version working next.
Be sure to use Java 8…Java 10 fails.
Be sure to offset the TCP port number. The default: 8080, interferes with Skype or some such thing. People seem to be using <http://localhost:1025/geoserver> to initiate their admin session.
When you log in as administrator, don’t use Firefox the first time. Explorer works for the first login, after which Firefox seems to start working.
Thanks again for the help.
Bill
Hi
plain:mypassword
Bill
Brad
