[Geoserver-users] Cannot publish layer: Error persisting CoverageInfoImpl
Dear list,
again, I've run into trouble. When creating new layers, even ones
based on the example data which are already published and working in
other layers, I get an error message:
Error persisting CoverageInfoImpl[test] to
/var/lib/tomcat7/webapps/geoserver/data/workspaces/sf/sfdem/test/coverage.xml
If I create two layers (first one failing) with the same name, I get
an error, that a layer with the same name already exists and then the
original error (see log)
Resource named 'test' already exists in store: 'sfdem'
This happens also if I modify an existing data store:
Error persisting WorkspaceInfoImpl[sf] to
/var/lib/tomcat7/webapps/geoserver/data/workspaces/sf/workspace.xml
To me it sounds as if there are permission problems, but I set the
owner and group to the tomcat user and permissions are set to 644, I
even tried 755 for the sfdem, but it didnt't work either. Is there
something else I need to take care of?
If I want to create a layer from GDAL image formats (just installed),
after the selection of the data source nothing happens. Not even an
error :frowning:
Another thing which is probably related is that in the WMS service
menu, there is no data store defined and when I choose one and hit
save, it returns to be empty
And one last observation which might help: In the developer logging
mode this message keeps on popping up:
2013-03-12 17:30:14,720 DEBUG [org.geoserver.web] - cannot convert
url: jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.5.jar!/org/geoserver/web/js/jquery.inline-info.js
to file (URI is not hierarchical), falling back to the inputstream for
polling
Thanks again for any help!
-Kristina
(still running Geoserver 2.2.5 on a Tomcat7 and using JAVA 1.6.0_27
(OpenJDK 64-Bit Server VM).)
log:
java.lang.IllegalArgumentException: Resource named 'test' already
  at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:381)
  at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:357)
  at org.geoserver.security.SecureCatalogImpl.add(SecureCatalogImpl.java:1006)
  at org.geoserver.catalog.impl.AbstractCatalogDecorator.add(AbstractCatalogDecorator.java:199)
  at org.geoserver.web.data.resource.ResourceConfigurationPage.doSave(ResourceConfigurationPage.java:298)
  at org.geoserver.web.data.resource.ResourceConfigurationPage$6.onSubmit(ResourceConfigurationPage.java:260)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1561)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:958)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
  at sun.reflect.GeneratedMethodAccessor259.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Method.java:616)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
  at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
  at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
  at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
  at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:146)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:97)
  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
  at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
  at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
  at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
  at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
  at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:309)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
  at java.lang.Thread.run(Thread.java:679)
2013-03-12 17:22:31,320 INFO [geoserver.web] - Error saving layer
org.geoserver.catalog.CatalogException: Error persisting
CoverageInfoImpl[test2] to
/var/lib/tomcat7/webapps/geoserver/data/workspaces/sf/sfdem/test2/coverage.xml
  at org.geoserver.config.GeoServerPersister.persist(GeoServerPersister.java:801)
  at org.geoserver.config.GeoServerPersister.persist(GeoServerPersister.java:788)
  at org.geoserver.config.GeoServerPersister.addCoverage(GeoServerPersister.java:541)
  at org.geoserver.config.GeoServerPersister.handleAddEvent(GeoServerPersister.java:90)
  at org.geoserver.catalog.impl.CatalogImpl.event(CatalogImpl.java:1327)
  at org.geoserver.catalog.impl.CatalogImpl.fireAdded(CatalogImpl.java:1291)
  at org.geoserver.catalog.impl.CatalogImpl.added(CatalogImpl.java:1280)
  at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:360)
Caused by: java.io.FileNotFoundException:
/var/lib/tomcat7/webapps/geoserver/data/workspaces/sf/sfdem/test2/coverage.xml.tmp
(No such file or directory)
  at java.io.FileOutputStream.open(Native Method)
  at java.io.FileOutputStream.<init>(FileOutputStream.java:209)
  at java.io.FileOutputStream.<init>(FileOutputStream.java:160)
  at org.geoserver.data.util.IOUtils.xStreamPersist(IOUtils.java:407)
  at org.geoserver.config.GeoServerPersister.persist(GeoServerPersister.java:794)
  ... 105 more
