[Geoserver-users] can't start geoserver
All,
I cannot get geoserver to start. It had been working but I removed my GWC tiles because i was going to recreate them with new styles. Log is below.
Steve
2012-06-26 14:08:28,992 INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
2012-06-26 14:08:29,162 INFO [storage.DefaultStorageFinder] - ********************************************************************************************************************
2012-06-26 14:08:29,162 INFO [storage.DefaultStorageFinder] - *** Found Java environment variable GEOSERVER_DATA_DIR set to /var/www/geo_data, using it as the default prefix. ***
2012-06-26 14:08:29,433 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
2012-06-26 14:08:29,454 INFO [config.XMLConfiguration] - Will look for geowebcache.xml in '/var/www/geo_data/gwc'
2012-06-26 14:08:29,457 INFO [config.XMLConfiguration] - Found configuration file in /var/www/geo_data/gwc
2012-06-26 14:08:29,503 INFO [config.XMLConfiguration] - Configuration file validated fine.
2012-06-26 14:08:29,523 INFO [config.XMLConfiguration] - Initializing GridSets from /var/www/geo_data/gwc
2012-06-26 14:08:29,523 INFO [config.XMLConfiguration] - Initializing layers from /var/www/geo_data/gwc
2012-06-26 14:08:29,523 INFO [layer.TileLayerDispatcher] - Configuration /var/www/geo_data/gwc contained no layers.
2012-06-26 14:08:29,611 INFO [storage.EntityStoreBuilder] - Neither disk quota page store' cache memory percent nor cache size was provided. Defaulting to 25% Heap Size
2012-06-26 14:08:31,579 INFO [storage.BDBQuotaStore] - Berkeley DB JE Disk Quota page store configured at /var/www/geo_data/gwc/diskquota_page_store
2012-06-26 14:08:31,581 INFO [storage.BDBQuotaStore] - Quota Store initialized. Global quota: 0.0 B
2012-06-26 14:08:31,583 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: /var/www/geo_data/gwc/geowebcache-diskquota.xml
2012-06-26 14:08:31,586 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
2012-06-26 14:08:31,586 INFO [diskquota.DiskQuotaMonitor] - 0 layers configured with their own quotas.
2012-06-26 14:08:31,587 INFO [diskquota.DiskQuotaMonitor] - 310 layers attached to global quota 500.0 MB
2012-06-26 14:08:31,669 INFO [diskquota.DiskQuotaMonitor] - Disk quota periodic enforcement task set up every 10 SECONDS
2012-06-26 14:08:32,687 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
2012-06-26 14:08:32,748 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller in a background job...
2012-06-26 14:08:32,791 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
2012-06-26 14:08:32,994 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 9 paths
2012-06-26 14:08:33,015 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
2012-06-26 14:08:33,015 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
2012-06-26 14:08:33,080 INFO [org.geoserver] - GeoServer configuration lock is enabled
2012-06-26 14:08:34,262 ERROR [context.ContextLoader] - Context initialization failed
java.lang.NullPointerException
         at org.geoserver.wms.WMS.getMaxAnimatorRenderingTime(WMS.java:443)
         at org.geoserver.wms.WMSLifecycleHandler.resetAnimatorExecutorService(WMSLifecycleHandler.java:77)
         at org.geoserver.wms.WMSLifecycleHandler.onApplicationEvent(WMSLifecycleHandler.java:133)
         at org.springframework.context.event.SimpleApplicationEventMulticaster$1.run(SimpleApplicationEventMulticaster.java:78)
         at org.springframework.core.task.SyncTaskExecutor.execute(SyncTaskExecutor.java:49)
         at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:76)
         at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:275)
         at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:737)
         at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:384)
         at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
         at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
         at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
         at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
         at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3972)
         at org.apache.catalina.core.StandardContext.start(StandardContext.java:4467)
         at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1251)
         at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:613)
         at org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:136)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
         at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
         at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
         at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
         at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
         at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
         at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:558)
         at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
         at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
         at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
         at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
         at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
         at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
         at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
         at java.lang.Thread.run(Thread.java:662)
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
