[Geoserver-users] Cascading WMTS from an Esri Server throws an error on preview
I am trying to cascade a WMTS layer from an Esri Server using Geoserver 2.18.2. No problems setting up the store and publishing the layer, but the layer previews with the error:
“Error rendering coverage on the fast path
java.lang.NullPointerException”
Here’s the get capabilities
https://gis.rvca.ca/server/rest/services/RVCA_DRAPE2019_Cache/MapServer/WMTS/1.0.0/WMTSCapabilities.xml
Note that the layer “RVCA_DRAPE2019_Cache” loads fine as WMTS in QGIS.
Any ideas on how to fix this?
Cliff
can you turn logging up to GeoTools developer and then try again.
Ian
Ian Turton
Actually, I’ve just had a quick try with 2.19.2 (all I have with me) during my coffee break and it works fine - so I’ll be interested to see what happens in 2,20
Ian
Ian Turton
And now I’ve tried in 2.20.4 and again all is fine.
So it may be something in 2.18.x - worth upgrading if you can.
Ian
Ian Turton
That’s amazing. It’s just a staging Geoserver so I will upgrade and try again.
Thanks!
Cliff
Ian
Ian
Ian
On Tue, 3 May 2022 at 14:57, Cliff Patterson <cpatterson@anonymised.com> wrote:
Cliff
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
Ian Turton
Ian Turton
