[Geoserver-users] Cluster settings - Couldn't resolve model type
After upgrading Geoserver to 2.9.0, I see the following warning in logs every time I open a "Cluster settings" tab:
WARN [form.AbstractTextComponent] - Couldn't resolve model type of Model:classname=[org.apache.wicket.model.CompoundPropertyModel$AttachedCompoundPropertyModel]:nestedModel=[Model:classname=[org.apache.w
icket.model.CompoundPropertyModel]:nestedModel=[{toggleSlave=true, topicName=VirtualTopic.>, connection=enabled, brokerURL=tcp://ng7:61616, durable=true, xbeanURL=./broker.xml, toggleMaster=false, embeddedBroker=disabled, CLUST
ER_CONFIG_DIR=/var/lib/geoserver/cluster, embeddedBrokerProperties=embedded-broker.properties, connection.retry=3, instanceName=ng6, readOnly=enabled, group=geoserver-cluster, connection.maxwait=10000}]] for [TextField [Compone
nt id = toggleSlave]], please set the type yourself.
Is it a bug I should report?
Best regards
Maciej
On Tue, May 31, 2016 at 12:24 PM, Maciej Filocha <m.filocha@anonymised.com>
So to be sure, it's a warning but the UI works anyways?
I would report it, yes
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
W dniu 31.05.2016 o 12:35, Andrea Aime pisze:
Yes, at least for reading.
Maciej
I agree with Andrea,
please, open a JIRA report, we'll fix it right away.
Simone Giannecchini
Visit GeoSolutions Enterprise Support Services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, May 31, 2016 at 12:55 PM, Maciej Filocha <m.filocha@anonymised.com> wrote:
Maciej
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. NetFlow Traffic Analyzer | Real-Time NetFlow Analysis - ManageEngine NetFlow Analyzer
Geoserver-users mailing list
W dniu 31.05.2016 o 14:20, Simone Giannecchini pisze:
https://osgeo-org.atlassian.net/browse/GEOS-7565
Maciej
