GeoServer supports "palette" - vendor parameter on WMS requests as
documented here:
- http://docs.geoserver.org/latest/en/user/services/wms/vendor.html
http://docs.geoserver.org/latest/en/user/tutorials/palettedimage/palettedimage.html#tutorials-palettedimages
This feature is usefull in some cases, such as producing PNG8 indexed image
with only 256 colors, as standard GeoServer quantization methods (octree or
mediancut) distort some colors too much on colorful topographic maps.
The problem is that palette parameter must be delivered on a WMS request.
For example when using layer group with sub layers representing different
SLD visualizations on different scales it would be necessary to have
separate palette files for each sub layers. However when accessing layer
group from WMS using layer group name only one palette file name can be
specified.
Also some clients do not support providing non-standard "palette" parameter
on WMS request.
So the actual question : is there any way to configure palette file
configuration statically to a Layer or Style configuration under workspaces?
regards,
Jakob
View this message in context: http://osgeo-org.1560.x6.nabble.com/Color-palette-statically-configured-on-a-Layer-or-a-Style-tp5132589.html
documented here:
- WMS vendor parameters — GeoServer 2.28.0 User Manual
Paletted Images — GeoServer 2.28.0 User Manual
specified.
What you are asking is not achievable in general. The output image can only
have 256 colors, and it might not be possible to combine all the original
layer
by layer pallettes into a single one that preserves all the original colors.
It might work only if the overall set of colors, unioning all the ones from
the original
palettes, sums to less than 256 colors total.
on WMS request.
workspaces?
No, there is no way, but have a single palette per layer (and one for the
whole
layer group) would make sense and I guess would be a welcome addition.
Patches welcomed
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
