[Geoserver-users] Colors suggestion for map - SLD
Hi folks,
I need some advice to choose colors for my maps (roads and it's varieties,
states, cities, etc) in order to create an SLD file..
I emulated Google Maps colors but they were rejected by the board because
they want something more 'homemade' (don't even ask me please want they
meant %-|)
I have looked for them a lot navigating the web but couldn't find anything
interesting..
Please! any opinion, link, piece of code will be so appreciated!
Thank you..
View this message in context: http://old.nabble.com/Colors-suggestion-for-map---SLD-tp29877285p29877285.html
http://colorbrewer2.org/ is an easy way to try out different color schemes for maps, and they provide a few default schemes that you can try out and tweak.
David Winslow
OpenGeo - http://opengeo.org/
On Mon, Oct 4, 2010 at 11:10 AM, giraam <sdjbm17@anonymised.com> wrote:
Hi folks,
I need some advice to choose colors for my maps (roads and it’s varieties,
states, cities, etc) in order to create an SLD file…
they want something more ‘homemade’ (don’t even ask me please want they
meant %-|)
I have looked for them a lot navigating the web but couldn’t find anything
interesting…
Thank you…
View this message in context: http://old.nabble.com/Colors-suggestion-for-map—SLD-tp29877285p29877285.html
Virtualization is moving to the mainstream and overtaking non-virtualized
environment for deploying applications. Does it make network security
easier or more difficult to achieve? Read this whitepaper to separate the
two and get a better understanding.
http://p.sf.net/sfu/hp-phase2-d2d
Geoserver-users mailing list
Hi folks,
meant %-|)
interesting..
I have a roads style using the Open Street Map data that you can see
at http://ian01.geog.psu.edu/geoserver/www/pa/pa3.html (you'll need to
zoom in to see the more minor roads) and the style is at
http://ian01.geog.psu.edu/geoserver/styles/roads.sld if you'd like to
use it.
Ian
Ian Turton
