[Geoserver-users] config.yaml when do I need to change the default file?
Thanks for the quick work-around. At least I now know that it´s nothing to do with port forwarding or other settings which could break my set-up if I start fiddling.
I´ll have to post the question on the opengeo-suite forum as to why the variable substitution isn´t working.
thanks agian,
Robert
2011/2/22 Robert Buckley <robertdbuckley@anonymised.com>:
Well, the bug seems to be in the geoserver-printing-plugin sample script.
Is it OK to file JIRAs for community plugins as well?
Robert, if you're using the OG Suite, you can use the print service
from GeoExplorer (it works ok except for v.2.3.3).
Oscar.
hi,
“you can use the print service from GeoExplorer (it works ok except for v.2.3.3).”…
…which is the version I have just installed!!
oh well!
Von: Oscar Fonts oscar.fonts@anonymised.com
An: geoserver-users@lists.sourceforge.net
Gesendet: Dienstag, den 22. Februar 2011, 9:54:55 Uhr
Betreff: Re: [Geoserver-users] config.yaml when do I need to change the default file?
Robert, if you’re using the OG Suite, you can use the print service
Oscar.
Index, Search & Analyze Logs and other IT data in Real-Time with Splunk
Collect, index and harness all the fast moving IT data generated by your
applications, servers and devices whether physical, virtual or in the cloud.
Deliver compliance at lower cost and gain new business insights.
Free Software Download: http://p.sf.net/sfu/splunk-dev2dev
Geoserver-users mailing list
Geoserver-users@anonymised.come.net
