Thanks Ian,
I think the issue may actually be that the Tomcat server had not been permitted to accept PUT requests whilst the others had.
I have updated the configuration files but now the GeoServer will not start.
I’m think this issue is unrelated as I think this is an issue with the configuration of the GeoWebCache now (probably unrelated). That said, I’m having trouble tracking down the offending setting. I’ve removed the gwc_layers folder temporarily and also the lock files and tmp folders in the gwc but still no luck.
Does anyone know which bit of the load up sequence could cause this message:
WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name ‘geoServerLoader’: org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name ‘geoWebCacheExtensions’: Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
Paul
Judging by the documentation if you get a 403 it thinks you are changing the name or type of the featuretype, so I would assume you have to send everything.
Ian
On 11 August 2016 at 12:15, Paul Wittle <P.Wittle@…7193…> wrote:
Hello,
How do you update the title and abstract of a feature type using REST?
I thought it used to work but I am now getting 403 whenever I use a PUT request. Do I have to include the full xml definition or just the elements I want to update?
new titlenew abstracttrue
Best Regards,
Paul
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports. http://sdm.link/zohodev2dev
Geoserver-users mailing list
Ian Turton
