Hello,
I am using Geoserver 1.7.0, Java 1.6.0 and Tomcat 6.0.18
When I create a new Geotiff Coverage Store using the instructions at:
http://geoserver.org/display/GEOSDOC/User+Tutorial+Coverage
I get "Could not obtain a reader for the CoverageDataSet. Please check
the CoverageDataSet configuration!" when I press Submit for the new
Coverage Store. The full stack trace is at the end of the message.
Thank you so much for any help/direction,
Barbara
Here is the output of gdalinfo on the Geotiff file:
Driver: GTiff/GeoTIFF
Files: avhrr8bit.tif
Size is 1807, 1807
Coordinate System is:
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",90],
PARAMETER["longitude_of_center",0],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-4537774.017512428574264,4537774.017512428574264)
Pixel Size = (5021.642854229329714,-5021.642854229329714)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-4537774.018, 4537774.018) (135d 0'0.00"W, 29d37'40.80"N)
Lower Left (-4537774.018,-4536334.620) ( 45d 0'32.72"W, 29d38'19.02"N)
Upper Right ( 4536334.620, 4537774.018) (135d 0'32.72"E, 29d38'19.02"N)
Lower Right ( 4536334.620,-4536334.620) ( 45d 0'0.00"E, 29d38'57.25"N)
Center ( -719.699, 719.699) (135d 0'0.00"W, 89d59'27.20"N)
Band 1 Block=1807x4 Type=Byte, ColorInterp=Gray
The following exception was thrown:
* class org.vfny.geoserver.global.ConfigurationException: Could not
obtain a reader for the CoverageDataSet. Please check the
Details:
org.vfny.geoserver.global.ConfigurationException: Could not obtain a
reader for the CoverageDataSet. Please check the CoverageDataSet
configuration!
at
org.vfny.geoserver.action.data.DataCoveragesNewAction.newCoverageConfig(DataCoveragesNewAction.java:102)
at
org.vfny.geoserver.action.data.CoverageStoresEditorAction.execute(CoverageStoresEditorAction.java:90)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at
org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at
org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at
org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at
org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at
org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at
at
org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at
at
org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at
at
org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at
at
org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at
at
org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at
at
org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at
org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at
at
at
org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
