There is no error in the log.
Here is the log.
Request: getServiceInfo
2015-07-23 12:07:34,251 INFO [geoserver.wms] -
Request: getMap
Time =
Filter = null
Buffer = 0
Format = image/png
Filters = null
SldBody = null
Sld = null
StyleUrl = null
RemoteOwsType = null
RemoteOwsURL = null
FormatOptions = {DPI=300}
Width = 2083
Height = 2083
Palette = null
Transparent = true
MaxFeatures = null
SRS = EPSG:900913
Styles = [StyleImpl[ name=default_vulnerabilitytool]]
Tiled = false
StyleFormat = sld
ValidateSchema = false
BgColor = java.awt.Color[r=255,g=255,b=255]
FeatureVersion = null
Interpolations =
TilesOrigin = null
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
Crs = PROJCS[“WGS84 / Google Mercator”,
GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Longitude”, EAST],
AXIS[“Latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Mercator_1SP”],
PARAMETER[“semi_minor”, 6378137.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“central_meridian”, 0.0],
PARAMETER[“scale_factor”, 1.0],
PARAMETER[“false_easting”, 0.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH],
AUTHORITY[“EPSG”,“900913”]]
Bbox = SRSEnvelope[3308687.6918252804 : 4278826.542818119, -1986917.4370345192 : -1016778.5860416807]
Env = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
StyleVersion = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
Version = 1.1.1
Request = GetMap
Get = true
BaseUrl = http://192.168.0.89:80/geoserver/
RawKvp = {BBOX=3308687.6918252804,-1986917.4370345192,4278826.542818119,-1016778.5860416807, MAP_RESOLUTION=300, SERVICE=WMS, HEIGHT=2083, REQUEST=GetMap, DPI=300, STYLES=, WIDTH=2083, TRANSPARENT=true, VERSION=1.1.1, FORMAT=image/png, FORMAT_OPTIONS=dpi:300, LAYERS=malawi_vulnerabilitytool:malawi_national_vulnerability_index, SRS=EPSG:900913}
RequestCharset = UTF-8
2015-07-23 12:07:34,660 INFO [geoserver.filters] - 192.168.0.89 “GET /geoserver/malawi_vulnerabilitytool/wms?BBOX=3308687.6918252804%2C-1986917.4370345192%2C4278826.542818119%2C-1016778.5860416807&HEIGHT=2083&WIDTH=2083&TRANSPARENT=true&map_resolution=300&VERSION=1.1.1&FORMAT=image%2Fpng&SERVICE=WMS&format_options=dpi%3A300&LAYERS=malawi_vulnerabilitytool%3Amalawi_national_vulnerability_index&REQUEST=GetMap&STYLES=&DPI=300&SRS=EPSG%3A900913” took 2677ms
2015-07-23 12:07:34,989 INFO [geoserver.filters] - 192.168.0.89 “GET /geoserver/pdf/print.pdf?spec=%7B%22units%22%3A%22m%22%2C%22srs%22%3A%22EPSG%3A900913%22%2C%22layout%22%3A%22A4%20portrait%22%2C%22dpi%22%3A300%2C%22mapTitle%22%3A%22Title%22%2C%22layers%22%3A%5B%7B%22baseURL%22%3A%22http%3A%2F%2F192.168.0.89%2Fgeoserver%2Fmalawi_vulnerabilitytool%2Fwms%22%2C%22opacity%22%3A1%2C%22singleTile%22%3Afalse%2C%22type%22%3A%22WMS%22%2C%22layers%22%3A%5B%22malawi_vulnerabilitytool%3Amalawi_national_vulnerability_index%22%5D%2C%22format%22%3A%22image%2Fpng%22%2C%22styles%22%3A%5B%22%22%5D%2C%22customParams%22%3A%7B%22TRANSPARENT%22%3Atrue%7D%7D%5D%2C%22pages%22%3A%5B%7B%22center%22%3A%5B3793757.1173217%2C-1501848.0115381%5D%2C%22scale%22%3A5500000%2C%22rotation%22%3A0%2C%22comment%22%3A%22safa%22%7D%5D%7D” took 3237ms
On Thu, Jul 23, 2015 at 11:55 AM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com> wrote:
Uhm… I cannot see anything strange in the pdf, apart from the fact that it does not include the legend items.
Do you have any errors / warning in GeoServer logs when you print?
Mauro
2015-07-23 9:22 GMT+02:00 Wondimagegn Tesfaye <wondim81@anonymised.com>:
Hello Mauro,
Yes, it produces a valid image.
I have attached the pdf file.
Thanks!
On Thu, Jul 23, 2015 at 9:59 AM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com> wrote:
does the legend url (http://localhost:8080/geoserver/malawi_vulnerabilitytool/wms?TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetLegendGraphic&EXCEPTIONS=application%2Fvnd.ogc.se_xml&LAYER=malawi_national_vulnerability_index&FORMAT=image%2Fpng) produce a valid image?
Can you attach the produced pdf, so that I can take a look?
Thanks
Mauro
2015-07-23 8:30 GMT+02:00 Wondimagegn Tesfaye <wondim81@anonymised.com>:
Dear Members,
I was trying to include legend in the pdf file but it is not being included. I see an empty box in place of the legend. Below is my code.
Spec.
"legends": [
"classes": [
"icons": [
"[http://localhost:8080/geoserver/malawi_vulnerabilitytool/wms?TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetLegendGraphic&EXCEPTIONS=application%2Fvnd.ogc.se_xml&LAYER=malawi_national_vulnerability_index&FORMAT=image%2Fpng](http://localhost:8080/geoserver/malawi_vulnerabilitytool/wms?TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetLegendGraphic&EXCEPTIONS=application%2Fvnd.ogc.se_xml&LAYER=malawi_national_vulnerability_index&FORMAT=image%2Fpng)"
"name": 'icon name',
"iconBeforeName": true
"name": 'Legend'
config.yaml
- !columns
# columns can have an absolute position. In that case, they need the 3 following fields:
absoluteX: 50
absoluteY: 300
width: 440
items:
- !legends
backgroundColor: #FFFFFF
borders: true
align: left
inline: true
maxHeight: 700
maxWidth: 200
defaultScale: 0.5
iconMaxWidth: 80
iconMaxHeight: 80
iconPadding: 3 0 0 0
columnMargin: 10
classIndentation: 3
classSpace: 5
backgroundColor: white
layerFontSize: 9
- !scalebar
type: bar_sub
Thanks!
Geoserver-users mailing list
