[Geoserver-users] Coverage Data sets disappear from the selectable list of maps.
I’m pretty new to GeoServer and am beginning to have a look at creating new Data Stores etc.
I began with a couple of vector maps and shapefiles. (Austria and Germany)
On the “geoserver/welcome.do” page I selected “Welcome / Config / Data / DataStores / New”.
Then selected “Shapefile” from the DataSet description drop down menu and then went through the creation of Feature Types etc.
That all seemed to work fine and when I went to “Welcome / Demo / Map Preview” my new dataStores were listed.
I then created some coverage stores of CADRG maps of Florida (RPFTiles) by selecting “Config / Data / Coverage Stores / New” and entering the url of the ‘.tif’ files.
This also seemed to work OK and these were also in the list when I did “Welcome / Demo / Map Preview”.
I pointed my client application at my wms server and displayed my vector maps (Austria and Germany) and my CADRG maps (Florida).
So far so good. At this point I shut the server down and went home.
When I restarted the Server the maps of Austria and Germany, i.e. the vector maps, were still in the list when I did a “Welcome / Demo / Map Preview” but the CADRG data (Florida) was no longer listed and therefore no longer accessible from the client application.
I ended up selecting "Config / Data / Coverage Stores " then deleting the Coverage Stores, then re-creating them and after I had done that they were back in the list of maps and available to the client application.
I then stopped and restarted my GeoServer service. Having done that the CADRG data was missing once again from the MapPreview list.
Does anybody know what I’m doing wrong, or does this always happen ?
Thanks
Peter Turvey
BAE Systems Integrated System Technologies Limited
Registered Office: Warwick House, PO Box 87, Farnborough Aerospace Centre, Farnborough, Hants, GU14 6YU, UK
Registered in England & Wales No: 3456325
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
Turvey, Peter G (UK) ha scritto:
I'm pretty new to GeoServer and am beginning to have a look at creating new Data Stores etc.
On the "geoserver/welcome.do" page I selected "Welcome / Config / Data / DataStores / New".
Then selected "Shapefile" from the DataSet description drop down menu and then went through the creation of Feature Types etc.
That all seemed to work fine and when I went to "Welcome / Demo / Map Preview" my new dataStores were listed.
I then created some coverage stores of CADRG maps of Florida (RPFTiles) by selecting "Config / Data / Coverage Stores / New" and entering the url of the '.tif' files.
This also seemed to work OK and these were also in the list when I did "Welcome / Demo / Map Preview".
When I restarted the Server the maps of Austria and Germany, i.e. the vector maps, were still in the list when I did a "Welcome / Demo / Map Preview" but the CADRG data (Florida) was no longer listed and therefore no longer accessible from the client application.
Does anybody know what I'm doing wrong, or does this always happen ?
Nope, it's definitely some kind of bug. Which version of GeoServer
are you using? How are you referring to the files in the configuration?
Are they on a local drive, on some remote server?
Andrea Aime
OpenGeo - http://opengeo.org
Ciao Peter,
I see two options:
1> a geoserver bug
2>> your data is not correctly configured and therefore it is skiiped on startup. I would test your data again but before doing that I would raise the geoserver logging level and then I would check the logs, looking for any error.
Anywya, if you can upload to our ftp some test data, we can test it for you.
Simone.
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, Nov 26, 2008 at 12:33 PM, Turvey, Peter G (UK) <Peter.Turvey@anonymised.com> wrote:
Thanks
Peter Turvey
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
