[Geoserver-users] CQL filter function, parse error
Hello All,
I am trying to use CQL filter function available in geoserver but it gives
me parse error.
Here is the filter function reference:
http://docs.geoserver.org/2.0.x/en/user/filter/function_reference.html
and I took example from this tutorial:
http://docs.geoserver.org/latest/en/user/tutorials/cql/cql_tutorial.html
I use strToUpperCase, for states layer in CQL:
strToUpperCase(STATE_NAME) like '%M%'
and error message comes:
Could not parse cql filter list.
encountered 'like' at line 1.
when I dont use strToUpperCase it works but why not filter function
strToUpperCase or strToLowerCase working?
Any help is appreciated.
Thanks in advance.
http://old.nabble.com/file/p30994722/CQL%2Bparse%2Berror.jpg
View this message in context: http://old.nabble.com/CQL-filter-function%2C-parse-error-tp30994722p30994722.html
IIRC we have switched from the ‘CQL2’ CQL module to the ‘ECQL’ one in GeoServer trunk. It seems that the older module (which you are still using) does not allow functions (only property names) as the left-hand-side of a ‘LIKE’ comparison.
I think updating to GeoServer 2.1 (not yet released, but in RC status) would allow you to use this filter. Alternatively, you can rewrite your filter using nested functions instead:
isLike(strToUpperCase(STATE_NAME) like ‘%M%’)
hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Wed, Feb 23, 2011 at 8:05 AM, SSA <sandeep_deep@anonymised.com…> wrote:
Hello All,
me parse error.
encountered ‘like’ at line 1.
Thanks in advance.
Free Software Download: Index, Search & Analyze Logs and other IT data in
Real-Time with Splunk. Collect, index and harness all the fast moving IT data
generated by your applications, servers and devices whether physical, virtual
or in the cloud. Deliver compliance at lower cost and gain new business
insights. http://p.sf.net/sfu/splunk-dev2dev
Geoserver-users mailing list
Thank you David for your reply and time but this didn't work either. I have
stable version in production so I am afraid if I can do anything to improve
search. I'll install 2.1 RC to see if this works there.
Its strange that documentation for 2.0 still mentions to use cql filter
function while they don't work.
David Winslow-5 wrote:
IIRC we have switched from the 'CQL2' CQL module to the 'ECQL' one in
using)
'LIKE' comparison.
would
isLike(strToUpperCase(STATE_NAME) like '%M%')
hope this helps.
David Winslow
On Wed, Feb 23, 2011 at 8:05 AM, SSA <sandeep_deep@anonymised.com> wrote:
View this message in context: http://old.nabble.com/CQL-filter-function%2C-parse-error-tp30994722p30995962.html
Oops, the CQL I posted was not what I meant. You can try this:
isLike(strToUpperCase(STATE_ABBR), ‘%M%’) == true
You could also look into using XML-encoded filters (like you use in SLD) instead of CQL.
David Winslow
On Wed, Feb 23, 2011 at 10:39 AM, SSA <sandeep_deep@anonymised.com> wrote:
Thank you David for your reply and time but this didn’t work either. I have
search. I’ll install 2.1 RC to see if this works there.
function while they don’t work.
using)
‘LIKE’ comparison.
would
hope this helps.
David Winslow
The functions do work, as David alreayd explained what you’re seeing is a limitation of the official
OGC CQL language (which is documented in its own OGC standard, I think it’s
the catalog one).
A CQL comparison can only have this structure:
whilst yours is
GeoServer 2.1 uses ECQL (extended CQL), a home grown set of extensions
on top of the standard CQL that makes the language more similar to SQL and
allows, among others, for the
form to be parsed successfully
Hope this helps
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 333 8128928
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
