I use Geoserver 1.5.3, Postgres 8.3 and PostGIS 1.3.3.
I use CQL Filter to show or hidden some filter. The filter work well with field which have type is varchar or numeric.
When I filter with a date field, it return a blank map, there is no feature. My syntax is OK. ex:
http://localhost:8080/geoserver/wms?bbox=-106.50754423141483,31.15167484283446,27.25649709701543,53.13852825164794&styles=&Format=application/openlayers&request=GetMap&layers=shredit:act&width=800&height=300&srs=EPSG:4326&cql_Filter=LAST_REACH%20before%202000-01-01T00:03:20Z
Type of LAST_REACH is date
Nguyễn Đình Toán
Neu khong doc duoc tieng Viet, vui long vao menu View → chon Encoding → chon Unicode (UTF-8). Cam on.
On Friday 05 December 2008 04:55:44 Toan Nguyen wrote:
The filter syntax is valid for CQL language.
cheers
Mauricio Pazos
www.axios.es
Hi Toan,
GeoServer 1.5.3 is a bit out dated... 1.7.0 is currently the stable version. And in particualr with regard to handling dates much work has been done. You may want to try a newer version of GeoServer to see if the issue is fixed. If not we can look into it deeper.
-Justin
Toan Nguyen wrote:
I use Geoserver 1.5.3, Postgres 8.3 and PostGIS 1.3.3. <http://1.3.3.>
Nguyễn Đình Toán
Neu khong doc duoc tieng Viet, vui long vao menu View --> chon Encoding --> chon Unicode (UTF-8). Cam on.
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can't happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
I know GeoServer 1.5.3 is out of date.
When I try update to 1.6.4, it make my program some error, so I still use GeoServer 1.5.3.
OK, I will try with GeoServer 1.7.0. And report to you.
On Fri, Dec 5, 2008 at 9:49 PM, Justin Deoliveira <jdeolive@…1671…> wrote:
Hi Toan,
GeoServer 1.5.3 is a bit out dated… 1.7.0 is currently the stable version. And in particualr with regard to handling dates much work has been done. You may want to try a newer version of GeoServer to see if the issue is fixed. If not we can look into it deeper.
-Justin
Justin Deoliveira
Nguyễn Đình Toán
