[Geoserver-users] Creating Image Mosaic from Files on a Networked Drive
Hello
I wonder if anyone can help.
I’m trying to create an Image Mosaic from some tif files stored on a network drive – S:.
However I can’t point Geoserver to a network location in the ImageMosaic plugin, just to the local files on the C:\ drive of the server. I’ve tried replacing S:\ with \server\share but that doesn’t work either.
I don’t really want to keep a second copy of these files, so is it possible to create a mosaic from a network location?
I also tried this http://osgeo-org.1560.x6.nabble.com/Image-Mosaicking-Plugin-and-UNC-paths-td3806076.html. Geoserver and Tomcat are both running as services on my installation as in this post.
The problem seems to be with this is that it definitely doesn’t recognise S:\ within the dbf file, and I can’t seem to get gdaltindex to write a UNC path.
Any help gratefully received.
Thanks
Sandra
Hi Sandra,
that seems strange.
I have some sample data contained into a network disk which I refer as V:\bigdisk... when configuring some mosaics and I have no issues.
Could you please provide us some more information?
  1. Which geoserver version are you using?
  2. How are you configuring the mosaic? (As an instance, I have a V:\bigdisk\mosaic folder containing several TIFFs… I have created an imageMosaic store referring to that folder and it worked fine. Or are you dealing instead with a properties file to define an external location through the IndexingDirectories parameter?)
Please, let us know.
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Thu, Oct 10, 2013 at 2:50 PM, Sandra Kennish <s.kennish@anonymised.com> wrote:
Hello
Thanks
Sandra
CONFIDENTIALITY: The contents of this message are the views of the author, not necessarily the views of the North York Moors National Park Authority. This is a private message intended for the named addressee(s) only. Its contents may be confidential.
If you have received this message in error please reply to say so and then delete the message. Any use, copying, disclosure or distribution by anyone other than the addressee is forbidden.
www.northyorkmoors.org.uk
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60134071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Sandra,
I’m keeping the discussion inside the mailing list so that in case I’m unable to provide some more help, someone else can probably do it.
Could you try to directly insert the mosaic path inside the ConnectionParameters: URL edit box? (Without using the “Browse” link)
In my example I have:
file://V:\bigdisk\data\mosaics\50cm
Where V: is the network drive.
Please let me know.
Daniele
On Thu, Oct 10, 2013 at 4:35 PM, Sandra Kennish <s.kennish@anonymised.com> wrote:
Hi Daniele
Thanks for your reply.
I’m using 2.3.5 and configuring the image mosaic by Clicking Add New Store, choosing ImageMosaic and clicking the Browse button and trying to navigate to a location. I can only see local files though and trying to enter the paths to the network in manually doesn’t work either. I just get the error: Could not find file: \server\share\folder
If I copy the files to a local folder on the actual Geoserver server then it works fine.
Regards
Sandra
Sandra Kennish
GIS Officer
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: 10 October 2013 14:53
To: Sandra Kennish
Subject: Re: [Geoserver-users] Creating Image Mosaic from Files on a Networked Drive
Hi Sandra,
that seems strange.
Daniele
Hello
Thanks
Sandra
Scanned by MailDefender - managed email security from intY - www.maildefender.net
Hi Daniele
I’ve typed in:
file://S:\OS_1_250_RASTER
but I just get an error: Could not find file: file://S:\OS_1_250_RASTER
The drives are showing on the server correctly – could it be permissions as I’m logged directly in to Geoserver as a Geoserver user, and while I have full access to these folders, the Geoserver user I’m using probably doesn’t. How would I give a Geoserver user file permissions?
Regards
Sandra
Sandra Kennish
GIS Officer
Hi Sandra,
Please let me know.
Daniele
On Thu, Oct 10, 2013 at 4:35 PM, Sandra Kennish <s.kennish@anonymised.com…> wrote:
Hi Daniele
Regards
Sandra
Sandra Kennish
GIS Officer
From: dany.geotools@anonymised.com..84… [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
To: Sandra Kennish
Hi Sandra,
that seems strange.
Daniele
Hello
Thanks
Sandra
Hi Sandra,
another question:
do you have proper permission on that drive?
Daniele
On Thu, Oct 10, 2013 at 4:45 PM, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Sandra,
Please let me know.
Daniele
Hi Daniele
Regards
Sandra
Sandra Kennish
GIS Officer
From: dany.geotools@anonymised.com84… [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
To: Sandra Kennish
Hi Sandra,
that seems strange.
Daniele
Hello
Thanks
Sandra
Ciao Sandra,
if you are running GeoServer as a service, you need to fiddle with the
account that is running that service to make sure it has acccess to
network drives.
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Thu, Oct 10, 2013 at 5:06 PM, Sandra Kennish
Hi Daniele
I’ve typed in:
Regards
Sandra
Sandra Kennish
GIS Officer
Daniele Romagnoli
Sent: 10 October 2013 15:46
To: Sandra Kennish; geoserver-users@lists.sourceforge.net
Networked Drive
Hi Sandra,
I'm keeping the discussion inside the mailing list so that in case I'm
ConnectionParameters: URL edit box? (Without using the "Browse" link)
Please let me know.
Daniele
information.
Hi Daniele
Could not find file: \\server\share\folder
works fine.
Regards
Sandra
Sandra Kennish
GIS Officer
Daniele Romagnoli
To: Sandra Kennish
Networked Drive
Hi Sandra,
that seems strange.
V:\bigdisk\... when configuring some mosaics and I have no issues.
1) Which geoserver version are you using?
2) How are you configuring the mosaic? (As an instance, I have a
V:\bigdisk\mosaic folder containing several TIFFs... I have created an
Daniele
information.
Hello
drive – S:\.
replacing S:\ with \\server\share but that doesn’t work either.
I also tried this
this post.
path.
Thanks
Sandra
from
from
On Thu, Oct 10, 2013 at 5:06 PM, Sandra Kennish <
Hi Daniele
I’ve typed in:
Have you tried with file://S:/OS_1_250_RASTER?
Just a shot in the dark, may not be it at all
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea
No afraid I get the same error. I’m off for a couple of days now, but I’ll try looking at permissions when I get back.
Regards
Sandra
Sandra Kennish
GIS Officer
On Thu, Oct 10, 2013 at 5:06 PM, Sandra Kennish <s.kennish@anonymised.com…> wrote:
Hi Daniele
I’ve typed in:
Ing. Andrea Aime
@geowolf
Technical Lead
Hello
Just to update I’ve managed to create the image mosaic by adding in the Geoserver server name to the folder containing my tif files and giving it full permission to start with and then reducing it to read once I’ve created the mosaic.
I had to use the UNC path to the files.
Thanks for all your suggestions.
Regards
Sandra Kennish
GIS Officer
From: Sandra Kennish [mailto:s.kennish@anonymised.com]
Sent: 10 October 2013 16:47
To: Andrea Aime
Hi Andrea
Regards
Sandra
Sandra Kennish
GIS Officer
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 10 October 2013 16:43
To: Sandra Kennish
Cc: Daniele Romagnoli; geoserver-users@lists.sourceforge.net
Hi Daniele
I’ve typed in:
Ing. Andrea Aime
@geowolf
Technical Lead
