[Geoserver-users] Creating Repository
I am new to Geoserver. Can somebody tell me if it is possible to create a central repository using Geoserver, where people can deposit data and be able to access it?
Regards
Smitha V
MT2009149
Yes, i have a postgres/postgis DB. Can you pls give the steps in more detail?
On Thu, Dec 30, 2010 at 7:30 PM, Meron <meralaz2000@…54…> wrote:
you will need a postgres/postgis DB and to create a web interface that enables users to load their data. It may require to put some hours of works but possible.
Meron A. Gebre
Software Engineer
Earth Resources Technology (ERT), Inc.,
Contractor to USGS/EROS
47914 252nd Street
Sioux Falls, SD 57198
Tel. : (605) - 594 - 6842
Fax. : (605) - 594 - 6119
mabrham@anonymised.com
Sent: Wed, 29 December, 2010 22:27:25
Subject: [Geoserver-users] Creating Repository
Regards
Smitha V
MT2009149
Regards
Smitha V
MT2009149
The solution probably lacked details because there are so many ways to
go about it. I don't think there are any plugins for geoserver for
uploading (though not a bad suggestion), so you'll have to pick your
favorite web development toolkit and build your own tool.
I would suggest looking at GeoDjango, Mapfish, Geomajas and some of the
other similar web frameworks specifically dealing with spatial data as
something mostly out of the box from one of those might work for you.
Basically you need a web interface to let users upload files. Then you
either need to load those files into a postgis database or use them as
is and setup a geoserver record for the data source.
Enjoy,
Alex
detail?
but possible.
Meron A. Gebre
Software Engineer
47914 252nd Street
*To:* geoserver-users@lists.sourceforge.net
*Sent:* Wed, 29 December, 2010 22:27:25
*Subject:* [Geoserver-users] Creating Repository
able to access it?
Regards
Smitha V
MT2009149
How to authenticate the users? Say for example, i want to allow only people in my office to have access to the files on the geoserver. How do i restrict the access to only those people?
Regards
Smitha V
MT2009149
Regards
Smitha V
MT2009149
IIITB
you should look into WFS-T, user can modify data using this service,
lookinto geoserver's demo urls
able to access it?
Regards
Smitha V
MT2009149
Regards
Smitha V
MT2009149
IIITB
Learn how Oracle Real Application Clusters (RAC) One Node allows customers
to consolidate database storage, standardize their database environment,
and,
should the need arise, upgrade to a full multi-node Oracle RAC database
without downtime or disruption
http://p.sf.net/sfu/oracle-sfdevnl
Geoserver-users mailing list
I.R
You can block all ip addresses not in your office using firewalls and/or
apache configurations.
Also have a look at GeoShield
http://code.google.com/p/geoshield/downloads/list
Enjoy,
Alex
able to access it?
Regards
Smitha V
MT2009149
You also could try http://geonode.org It built on GeoServer and has a shapefile/geotiff through the web uploader, and we’re working on an ftp uploader (which will be a geoserver community module). It uses Django as a web framework, and its user access hooks in to GeoServer’s security, so you can use its gui to limit user access. Also does things like styling through the web and provides CS-W on layers uploaded, with metadata editing that gets picked up by GeoServer and GeoNetwork. It’s a lot of software to set up and coordinate, but we just about done with ubuntu packages that should be released shortly.
On Thu, Dec 30, 2010 at 10:43 PM, Smitha V <smitha.v@anonymised.com3…> wrote:
Meron A. Gebre
Software Engineer
47914 252nd Street
Regards
Smitha V
MT2009149
Regards
Smitha V
MT2009149
to consolidate database storage, standardize their database environment, and,
