[Geoserver-users] cropping overlay into a circle
Is there a way to crop an overlay into a circle using a radius? Either through an SLD or WPS? For example: In an sld you’d color the radius and make the rest transparent. Is that possible?
Dominique Bessette
On Tue, Sep 22, 2015 at 11:20 PM, Bessette-Halsema, Dominique E <
Yes, there are the bits to do it for both vector layers (using geometry
transformations) and raster layers (using rendering transformations)
but personally I never tried to do that.
We have no way to do that by just passing a parameter into a request
though, it has to be built into a specific set of styles
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
