[Geoserver-users] CSS (or SLD) styling: create label-geometry from 2 layer attributes
Hi all
I am trying to use 2 numeric attributes called label_lat and label_lng to create a point geometry for the labeling of a polygon.
Can anyone point me to the correct format, if this is indeed possible?
I cannot find the information on https://docs.geoserver.org/latest/en/user/styling/css/index.html
I have tried:
label-geometry: [label_lng], [label_lat];
label-geometry: [(label_lng, label_lat)];
etc
and the reverse coordinate orders
label-geometry: [centroid(geom)]; does work as expected, but I need more control.
I also cannot create a new column in the GeoServer SQL view that is visible in the output e.g. ST_Point (label_lng, label_lat, 4326) as label-geom
i.e. if I create the new column, it must not be visible in the output.
Thanks
Peter
There should be a function to create a point from lat, Lon but I do not see it in the function list. It is a little to do anything other than transform the main geometry - since often the data is queried using a BBOX against the main geometry.
For greater control I would recommend use the centroid as a staring location, and provide an offset to determine the label position. The offset can be expressed as an expression which you can adjust for scale.
Reference:
Jody Garnett
I usually use geomFromWKT(geometry) with a string like ‘POINT(’+x+’ ‘+y+’)’ as the parameter. But a nicer function would be useful.
There is also a pole of accessibility function that is better than centroid if you have oddly shaped polygons.
Ian
Jody Garnett
Ian Turton
Thank you very much for your answers. All 3 of them are super useful.
Ian, I do not have the luxury of building up the string in a single attribute, so I need to use the Concatenate or strConcat functions from Jody’s reference. Andrea, the WKT X and Y coordinates are not separated by a comma but rather by a space.
The strConcat function only joins 2 strings, the Concatenate function is able to join many strings.
So something like this should work:
label-geometry: [geomFromWKT(Concatenate(‘POINT(’, label_lng, ’ ', label_lat, ‘)’))];
or
label-geometry: [geomFromWKT(strConcat(strConcat(strConcat(strConcat(‘POINT(’, label_lng), ’ '), label_lat), ‘)’))];
However, the SLD created contains (for the space separator between X and Y):
ogc:Literal </ogc:Literal>
and it appears from my testing and debugging that this is evaluated as “” i.e. an empty string.
(I get the exception: bad wkt when evaluating it, and I have confirmed the above in Eclipse)
Trying to force a &nbsp; into the Literal does not work.
Is there a bug with parsing a literal space?
So, I am very close to my solution, I just need a way to represent a literal space, if anyone can assist, please?
Thanks
Peter
Jody Garnett
Ian Turton
White space gets reduced in the XML, so you might need a cdata block around it. Not sure how CSS handles it.
Ian
Jody Garnett
Ian Turton
Thanks Ian, you’re 100% right. I was able to manually edit the SLD produced by the CSS translator to:
ogc:Literal</ogc:Literal>
and then my label-geometry worked as expected.
I believe this might be a bug in the CSS extension, which I have logged in Jira: https://osgeo-org.atlassian.net/browse/GEOT-7486
Thank you Andrea, Jody and Ian for your help.
Peter
Jody Garnett
Ian Turton
