[Geoserver-users] CSS plugin difficulties
Hiya,
When using the CSS plugin and pressing the Submit button to save a CSS style, it seems to be MUCH slower in GeoServer 2.3.x than 2.2.x versions.
For our larger styles (150 lines of CSS becoming 1200 lines of SLD) it has gone from a reasonable speed,
to forcing us to restart GeoServer rather than wait for it to finish. Has anyone else noticed this?
Also (only tried in GeoServer 2.3.1) , using mark: url() now forces us to specify a protocol, is this expected?
Many thanks
Simon Hartley
*** This communication has been sent from World Fuel Services
Corporation or its subsidiaries or its affiliates for the intended recipient
only and may contain proprietary, confidential or privileged information.
If you are not the intended recipient, any review, disclosure, copying,
use, or distribution of the information included in this communication
and any attachments is strictly prohibited. If you have received this
communication in error, please notify us immediately by replying to this
communication and delete the communication, including any
attachments, from your computer. Electronic communications sent to or
from World Fuel Services Corporation or its subsidiaries or its affiliates
may be monitored for quality assurance and compliance purposes.***
I didn't know about any performance decrease for the CSS extension in
GeoServer 2.3 compared to 2.2 - to my knowledge they are using the exact
same conversion routine. It's possible that GeoServer is "locking up" due
to memory use - what are your JVM settings? (in particular the -Xmx and
-XX:MaxPermSize options are of interest.) If you don't mind sharing your
CSS style I'd be interested in seeing it as well.
I do have some changes that I've been sitting on for a while which should
improve performance, I'll try and get those released ASAP.
David Winslow
OpenGeo - http://opengeo.org/
On Wed, May 1, 2013 at 12:25 PM, Simon Hartley <SHartley@anonymised.com>wrote:
Hiya,****
style, it seems to be MUCH slower in GeoServer 2.3.x than 2.2.x versions.*
gone from a reasonable speed,****
anyone else noticed this?****
specify a protocol, is this expected?****
Many thanks****
Simon Hartley****
recipient
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Geoserver-users mailing list
Hi David,
It doesn’t seem to be memory related (when looking using VisualVM). We use: -Xmx2048M and –XX:MaxPermSize=128m.
The maximum the perm gen goes to is about 80MB and the heap about 750MB.
Perhaps there’s some extra work going on with the new UI that’s not related to the conversion.
I’ll share the CSS in a private email.
Thank you,
Simon
From: David Winslow [mailto:dwinslow@anonymised.com]
Sent: 01 May 2013 17:35
To: Simon Hartley
Cc: geoserver-users@anonymised.comrceforge.net
Subject: Re: [Geoserver-users] CSS plugin difficulties
I didn’t know about any performance decrease for the CSS extension in GeoServer 2.3 compared to 2.2 - to my knowledge they are using the exact same conversion routine. It’s possible that GeoServer is “locking up” due to memory use - what are your JVM settings? (in particular the -Xmx and -XX:MaxPermSize options are of interest.) If you don’t mind sharing your CSS style I’d be interested in seeing it as well.
I do have some changes that I’ve been sitting on for a while which should improve performance, I’ll try and get those released ASAP.
David Winslow
On Wed, May 1, 2013 at 12:25 PM, Simon Hartley <SHartley@anonymised.com> wrote:
Hiya,
Many thanks
Simon Hartley
I’ve just discovered that if I go to the CSS style editor, choose “Create a new style”, then press the “Create” button, seemingly nothing happens.
The spinning animation appears very briefly, but that’s it.
Does this mean that my data_dir is screwed?
Reloading Configuration and catalog doesn’t seem to help.
Best regards,
Simon
From: Simon Hartley [mailto:SHartley@anonymised.com]
Sent: 01 May 2013 18:04
To: geoserver-users@anonymised.comnet
Hi David,
Thank you,
Simon
To: Simon Hartley
David Winslow
On Wed, May 1, 2013 at 12:25 PM, Simon Hartley <SHartley@anonymised.com…> wrote:
Hiya,
Many thanks
Simon Hartley
Geoserver-users@anonymised.comists.sourceforge.net
