On Thu, Nov 5, 2015 at 7:54 AM, Derek Watling <derek@anonymised.com> wrote:
Thanks Andrea
I would like a line-break more
Right now I am not in the position to edit the code.
Can you at least open a ticket?
https://osgeo-org.atlassian.net/projects/GEOS/summary
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
