[Geoserver-users] Custom InfluxDB datastore - implementing filtering
So I've managed to make DataStore that connects to InfuxDB and fetches the
data. Now, I would like to implement filtering with CQL, so that I don't
fetch all data from DB, but only the ones that I specify.
Specifically, based on the parameters I enter (for example 4/10 parameters),
I would execute specific InfluxQL query on database and fetch data with only
those 4 parameters.
I think that postgis plugin works that way, you specify the parameters in
CQL and from it the SQL query is created and only specified data is fetched.
I want to accomplish basically the same thing.
I was wondering is there any tutorial/documentation for this, where I can
find how to implement this kind of filtering? What is the best approach
regarding this?
Best regards,
Maja
View this message in context: http://osgeo-org.1560.x6.nabble.com/Custom-InfluxDB-datastore-implementing-filtering-tp5303706.html
You need to look at (for example) PostgisFilterToSQL - which is where the generic GeoTools filter is converted to the database specific SQL query. The *FilterToSQL classes are written as visitors which walk down the filter tree and carry out an operation at each node of the tree. Other DB specific parts of the query (encoding geometry etc) are handled in the Dialect class.
IFAIK there is no tutorial for this as it isn’t something that gets done very often, your best bet is to discuss any problems you run in to on the GeoTools lists.
Ian
On 17 January 2017 at 11:48, Firefly <maja.filakovic@anonymised.com> wrote:
So I’ve managed to make DataStore that connects to InfuxDB and fetches the
data. Now, I would like to implement filtering with CQL, so that I don’t
those 4 parameters.
regarding this?
Best regards,
Maja
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Hi Maja,
Ian’s dead-on. If you are calling to InfluxDB directly, your options are to handle certain filters manually (which is great for a prototype!) or implement a visitor (again, you can focus on certain predicates first).
As an alternative solution, it appears that there is at least one JDBC connector for InfluxDB (https://github.com/influxdata/influxdb-java). You could plug that JDBC connector into the general GeoTools JDBCDataStore by mirroring what is done in the PostGIS DataStore.
The advantage of the first approach is that you’d be plumbing things directly, and it might be more clear what is happening. With the JDBC approach, the general GeoTools FilterToSQL code would do lots of the heavy lifting for you, so that’s win. On the downside, you’d have to learn an extra level of abstraction and you’d be reliant on the JDBC implementation.
As Ian said, this is a somewhat uncommon task, so asking on the lists would be a great way to get more help! Also, I hope you can share your implementation; wiring up InfluxDB to GeoServer sounds like a great project!
Jim
As a concrete example of a non-trivial, non-sql visitor, check out this class from ElasticGeo: https://github.com/ngageoint/elasticgeo/blob/master/gt-elasticsearch-parent/gt-elasticsearch-core/src/main/java/mil/nga/giat/data/elasticsearch/FilterToElastic.java.
If you are willing to read Scala, check out this which maps CQL to CQEngine queries: https://github.com/locationtech/geomesa/blob/master/geomesa-memory/geomesa-cqengine/src/main/scala/org/locationtech/geomesa/memory/cqengine/utils/CQEngineQueryVisitor.scala with unit tests: https://github.com/locationtech/geomesa/blob/master/geomesa-memory/geomesa-cqengine/src/test/scala/org/locationtech/geomesa/memory/cqengine/utils/CQEngineQueryVisitorTest.scala. GeoMesa has a few other visitors here and there; I think that one is the easiest to read.
If you haven’t seen it, this tutorial should help with the general datastore bits: http://docs.geotools.org/stable/userguide/tutorial/datastore/index.html
Ian
those 4 parameters.
regarding this?
Best regards,
Maja
Geoserver-users@anonymised.comsourceforge.net
Ian Turton
Check out the vibrant tech community on one of the world's most
engaging tech sites, SlashDot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
thank you for both your inputs. I'll look into that and try to implement
this. Right now, implementation of this is on the hold, but I hope that I'll
finish someday in the near future, when I'll have more free time.
Thanks again.
Maja
Jim Hughes wrote
Hi Maja,
Ian's dead-on. If you are calling to InfluxDB directly, your options
The advantage of the first approach is that you'd be plumbing things
heavy lifting for you, so that's win. On the downside, you'd have to
learn an extra level of abstraction and you'd be reliant on the JDBC
implementation.
project!
Jim
CQEngine queries:
with unit tests:
easiest to read.
If you haven't seen it, this tutorial should help with the general
datastore bits:
IFAIK there is no tutorial for this as it isn't something that gets
Ian
On 17 January 2017 at 11:48, Firefly &lt;
maja.filakovic@
&gt; &lt;mailto:
maja.filakovic@
&gt;> wrote:
    fetches the
    don't
    parameters),
    with only
    those 4 parameters.
    parameters in
    is fetched.
    where I can
    approach
    regarding this?
    Best regards,
    Maja
&lt;http://osgeo-org.1560.x6.nabble.com/Custom-InfluxDB-datastore-implementing-filtering-tp5303706.html&gt;
    &lt;mailto:
&gt;
    &lt;https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
Ian Turton
View this message in context: http://osgeo-org.1560.x6.nabble.com/Custom-InfluxDB-datastore-implementing-filtering-tp5303706p5304003.html
