[Geoserver-users] DataSource not available after calling dispose() or before being set
I am getting:
code=”internalError”Rendering process failed
DataSource not available after calling dispose() or before being set.
I am on GeoServer 2.17.2 on RedHat and using Andrea’s workspace from the osm-styles repo and connecting to a PostGIS DataStore which I loaded with some OSM data via imposm.
I get this error somewhat randomly and if I restart GeoServer, it seems to stop happening for a while but will eventually come back (even when making the exact same WMS request for an exact / known area that worked earlier).
Is this something that may be fixed in a later version of GeoServer? Does it have something to do with the speed of the connection to my DataStore? Any tips would be appreciated as this is a tough one for me. Thank you!
PS: If I re-enter my DataStore passwd and Save, that seems like it may trigger the error on subsequent requests.
Ashley Mort
Sr. Software Engineer
972-638-6317 office
814-571-3039 cell
Ashley:
You are the first person to report this error (although I suspect others may of also seen it and assumed someone else has reported).
Can I ask for some more detail? There should be a stack tract in the logs associated with this error; it may give us a clue which DataSource is causing problems.
The changing the database connection parametes is a good clue! I may expect a problem for rendering that occurs right when the connection is interrupted.
Jody
Jody Garnett
I think I know what’s going on. The pre-generalized data store is used there to have multiple generalized tables behind a single
layer. The store uses Repository to fetch the original stores and features sources… which per se is not bad, but it ends up
holding on to them, which is bad instead.
The ResourcePool under pressure, or due to re-configuration, can dispose of the store instances and create new ones, and then
the pre-generalized store ends up having dangling objects which throw that exception.
The work-around is to call “reset” after config changes.
The fix is to go into the pre-generalized store and make it stop holding references, and call onto the Repository every time
it needs a FeatureSource.
A bug report is welcomed, an actual fix much more so.
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks Jody and Andrea. I just saw these replies, sorry! Here is my stacktrace. I will try to work on making a bug report for this but I’ve never done that before. Thanks again!
2021-04-25 20:59:48,271 INFO [geoserver.wms] -
Request: getMap
Angle = 0.0
BaseUrl = http://localhost:8080/geoserver/
Bbox = SRSEnvelope[-1.001875417E7 : 0.0, 1.0018754169999998E7 : 2.003750834E7]
BgColor = java.awt.Color[r=255,g=255,b=255]
Buffer = 0
Clip = null
CQLFilter = null
Crs = PROJCS[“WGS84 / Google Mercator”,
GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Longitude”, EAST],
AXIS[“Latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Mercator_1SP”],
PARAMETER[“semi_minor”, 6378137.0],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“central_meridian”, 0.0],
PARAMETER[“scale_factor”, 1.0],
PARAMETER[“false_easting”, 0.0],
PARAMETER[“false_northing”, 0.0],
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH],
AUTHORITY[“EPSG”,“900913”]]
Elevation =
Env = {}
Exceptions = SE_XML
FeatureId = null
FeatureVersion = null
Filter = null
Format = image/png8
FormatOptions = {}
Get = true
Height = 1024
Interpolations =
Layers = [org.geoserver.wms.MapLayerInfo@…10823…, org.geoserver.wms.MapLayerInfo@…10824…, org.geoserver.wms.MapLayerInfo@…10825…, org.geoserver.wms.MapLayerInfo@…10826…, org.geoserver.wms.MapLayerInfo@…10827…, org.geoserver.wms.MapLayerInfo@…10828…, org.geoserver.wms.MapLayerInfo@…10829…, org.geoserver.wms.MapLayerInfo@…10830…, org.geoserver.wms.MapLayerInfo@…10831…, org.geoserver.wms.MapLayerInfo@…10832…, org.geoserver.wms.MapLayerInfo@…10833…, org.geoserver.wms.MapLayerInfo@…10834…, org.geoserver.wms.MapLayerInfo@…10835…, org.geoserver.wms.MapLayerInfo@…10836…, org.geoserver.wms.MapLayerInfo@…10837…, org.geoserver.wms.MapLayerInfo@…10838…, org.geoserver.wms.MapLayerInfo@…10839…, org.geoserver.wms.MapLayerInfo@…10840…, org.geoserver.wms.MapLayerInfo@…10841…, org.geoserver.wms.MapLayerInfo@…10842…, org.geoserver.wms.MapLayerInfo@…10843…, org.geoserver.wms.MapLayerInfo@…10844…]
MaxFeatures = null
Palette = null
RawKvp = {FORMAT=image/png8, STYLES=, WIDTH=1024, HEIGHT=1024, LAYERS=osm:osm, EXCEPTIONS=SE_XML, GWC_SEED_INTERCEPT=true, REQUEST=GetMap, SRS=EPSG:900913, BBOX=-10018754.17,10018754.169999998,0.0,20037508.34, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=true}
RemoteOwsType = null
RemoteOwsURL = null
Request = GetMap
RequestCharset = UTF-8
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = EPSG:900913
StartIndex = null
StyleBody = null
StyleFormat = sld
Styles = [StyleImpl[ name=simplified_water], StyleImpl[ name=water], StyleImpl[ name=coast_poly], StyleImpl[ name=world], StyleImpl[ name=icesheet], StyleImpl[ name=icesheet_outlines], StyleImpl[ name=all_regions], StyleImpl[ name=landusages], StyleImpl[ name=waterareas], StyleImpl[ name=waterways], StyleImpl[ name=buildup], StyleImpl[ name=all_boundaries], StyleImpl[ name=boundaries], StyleImpl[ name=transport_areas], StyleImpl[ name=buildings], StyleImpl[ name=roads], StyleImpl[ name=states], StyleImpl[ name=addresses], StyleImpl[ name=admin_labels], StyleImpl[ name=places], StyleImpl[ name=amenities], StyleImpl[ name=transport_points]]
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = true
ValidateSchema = false
Version = 1.1.1
ViewParams = null
Width = 1024
2021-04-25 20:59:48,320 ERROR [renderer.lite] - DataSource not available after calling dispose() or before being set.
java.lang.IllegalStateException: DataSource not available after calling dispose() or before being set.
at org.geotools.jdbc.JDBCDataStore.getDataSource(JDBCDataStore.java:458)
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:2116)
at org.geotools.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:2074)
at org.geotools.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:2104)
at org.geotools.jdbc.JDBCFeatureSource.buildFeatureType(JDBCFeatureSource.java:179)
at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:327)
at org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:296)
at org.geotools.jdbc.JDBCQueryCapabilities.supportsPropertySorting(JDBCQueryCapabilities.java:77)
at org.geotools.jdbc.JDBCQueryCapabilities.supportsSorting(JDBCQueryCapabilities.java:54)
at org.geotools.data.store.ContentFeatureSource$2.supportsSorting(ContentFeatureSource.java:1172)
at org.geotools.data.gen.PreGeneralizedFeatureSource$1.supportsSorting(PreGeneralizedFeatureSource.java:342)
at org.vfny.geoserver.global.GeoServerFeatureSource.getFeatures(GeoServerFeatureSource.java:364)
at org.vfny.geoserver.global.GeoServerFeatureSource.getFeatures(GeoServerFeatureSource.java:71)
at org.geotools.renderer.lite.StreamingRenderer.getFeatures(StreamingRenderer.java:2336)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2213)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:900)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:601)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:275)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:135)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:749)
at org.geoserver.wms.GetMap.run(GetMap.java:300)
at org.geoserver.wms.GetMap.run(GetMap.java:123)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:246)
at jdk.internal.reflect.GeneratedMethodAccessor359.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:38)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:55)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:31)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:61)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:41)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:50)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy113.getMap(Unknown Source)
at jdk.internal.reflect.GeneratedMethodAccessor314.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:877)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:265)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.geoserver.gwc.GWC.dispatchOwsRequest(GWC.java:1369)
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:706)
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:651)
at org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:852)
at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:140)
at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:78)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:33)
at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:22)
at org.geoserver.gwc.seed.SeederThreadLocalTransferExecutor.lambda$submit$1(SeederThreadLocalTransferExecutor.java:52)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:835)
2021-04-25 20:59:48,339 INFO [geoserver.wms] -
Request: getMap
Angle = 0.0
Bbox = SRSEnvelope[0.0 : 1.0018754169999998E7, 1.0018754169999998E7 : 2.003750834E7]
Buffer = 0
Clip = null
CQLFilter = null
GEOGCS[“WGS 84”,
UNIT[“m”, 1.0],
AXIS[“x”, EAST],
AXIS[“y”, NORTH],
Elevation =
Env = {}
Exceptions = SE_XML
FeatureId = null
Filter = null
Format = image/png8
FormatOptions = {}
Get = true
Height = 1024
Interpolations =
MaxFeatures = null
Palette = null
RawKvp = {FORMAT=image/png8, STYLES=, WIDTH=1024, HEIGHT=1024, LAYERS=osm:osm, EXCEPTIONS=SE_XML, GWC_SEED_INTERCEPT=true, REQUEST=GetMap, SRS=EPSG:900913, BBOX=0.0,10018754.169999998,10018754.169999998,20037508.34, VERSION=1.1.1, SERVICE=WMS, TRANSPARENT=true}
RemoteOwsURL = null
Request = GetMap
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = EPSG:900913
StartIndex = null
StyleBody = null
StyleFormat = sld
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = true
Version = 1.1.1
ViewParams = null
Width = 1024
2021-04-25 20:59:48,349 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:642)
Caused by: java.lang.IllegalStateException: DataSource not available after calling dispose() or before being set.
… 43 more
2021-04-25 20:59:48,354 ERROR [seed.MTSeeder] - Problem communicating with GeoServer
org.geowebcache.GeoWebCacheException: Problem communicating with GeoServer
at org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:657)
Caused by: java.lang.IllegalStateException: Expected: RenderedImageMap, got null
at org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:709)
… 10 more
Ashley Mort
972-638-6317 office
814-571-3039 cell
On Wed, Mar 10, 2021 at 3:33 PM Jody Garnett <jody.garnett@…84…> wrote:
Ashley:
Jody
On Tue, Mar 9, 2021 at 5:22 PM Ashley Mort via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
I am getting:
Ashley Mort
972-638-6317 office
814-571-3039 cell
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Jody Garnett
