Hay everybody!
I would like to know if geoserver has a debug mode ?
Thanks
Jim
Hay everybody!
Thanks
Jim
Jimmy Aumard wrote:
Hay everybody!
Thanks
Jim
If you are getting errors, then you can go into Config -> Server
Enable VerboseExceptions, and try various logging profiles, either GeoTools or GeoServer developer, for instance.
If you *really* want to debug, then you should run GeoServer through Eclipse:
http://geoserver.org/display/GEOSDOC/Developers+Guide
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
