I have an instance of Geoserver running in debug in eclipse.
I want to debug with the oracle extension but Oracle NG never shows in the
add store page.
I compiled with the extension using mvn eclipse:eclipse -P oracle
successfully but still Oracle NG isn't showing up.
Thanks for your help.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
It’s been a while since I did this but I think I set the profile in the maven → set maven profiles menu for the gs-web module. Though I use the built in maven in eclipse rather than eclipse:eclipse so it may not work for you.
Ian
Ian Turton
Been a while here too
By a quick look in the pom file it seems that two profiles need to be enabled, a “oracle” one to get the extension in, but it will
still not work as the oracle driver is not included (it’s not redistributable), then add a “oracleDriver” profile after manually installing the
driver in maven matching this description:
com.oracle
ojdbc7
12.1.0.2
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
