[Geoserver-users] Delete user with REST api?
Hi List,
I’ve been able to create users with the REST api, now I want to be able to delete them. Have tried to follow docs from https://docs.geoserver.org/stable/en/user/rest/api/userrole.html and https://docs.geoserver.org/latest/en/api/#1.0.0/usergroup.yaml
but so far no success - have tried with 2.16 and 2.17. Does anyone have a working example?
Gus
Hi Gus,
I checked and I also could not delete a user by the REST API (tested with GeoServer v2.17.1). I could load the users by doing a HTTP GET request
http://localhost:8080/geoserver/rest/security/usergroup/users
If I try to remove a user (user is existing) by HTTP DELETE against http://localhost:8080/geoserver/rest/security/usergroup/users/testDeleteMe I get
“The origin server did not find a current representation for the target resource or is not willing to disclose that one exists”.
The APIs here [1] do not work at all.
Maybe we both are missing something or this is a bug? Any help / hint welcome.
Regards
Chris
[1] https://docs.geoserver.org/stable/en/api/#1.0.0/usergroup.yaml
Am 29.06.20 um 13:39 schrieb Thuser - Services:
Hi List,
Gus
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: [http://www.ianturton.com/talks/foss4g.html#/](http://www.ianturton.com/talks/foss4g.html#/)
- The GeoServer user list posting guidelines: [http://geoserver.org/comm/userlist-guidelines.html](http://geoserver.org/comm/userlist-guidelines.html)
If you want to request a feature or an improvement, also see this: [https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer](https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer)
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
I don’t have an example, nor I have experience using that part of the API, but the source code is there:
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/rest/security/UsersRestController.java#L94
So it seems the path to use would be http://localhost:8080/geoserver/rest/security/usergroup/user/{user}
Unfortunately this class seems to have no tests, I’m baffled it managed to get into a core module… thankfully
some years ago we started restricting how code gets in, situations like this one are unlikely to happen any more.
I cannot help further with this security matter, but surely motivates me to work on adding more QA checks on
code contributions
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
