On Fri, Nov 15, 2013 at 12:30 PM, Rudy Commenge <rudywi.devel@anonymised.com>wrote:
The internal structure is not modified.
But a common user, retrieve features (with GetFeature) in a different
format generated by XSLT extension.
I'm not talking about the internal structure, I'm referring to the external
one, the one that the user end up
seeing.
A WFS has one, and just one, exposed structure for the feature types,
described in XML schema, any
request to GetFeature must be able to refer to the attributes listed there
in filters and property subsetting.
There is no possibility for exposing more than one structure, that makes no
sense.
If you want to have an internal structure that's different than the one
you're exposing, then you're using
the wrong tool for the job, you should be looking into app-schema instead.
An XSLT tool that allows to manipulate structure is conceivable, but it
would be much harder than you
think, it would also have to be able to remap not only DescribeFeatureType,
but also any incoming
GetFeature request (in particular, the list of property names, and the
Filter).
This is not what the XSLT _output format_ generator does.
An output format is just a different way of representing the same data, not
a way to change the exposed
structure.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
