[Geoserver-users] Determining Geoserver patch version when using x.y-SNAPSHOT in context of CVE-2024-36401
Hi All,
In light of the recent-ish
CVE: https://www.opencve.io/cve/CVE-2024-36401 I am going around and checking our geoserver versions to check if they are vulnerable. I am a little stumped.
We use the official geoserver images tagged
'docker.osgeo.org/geoserver:2.24.x'. In the web interface of a
geoserver so running, the version is reported as 2.24-SNAPSHOT.
According to the CVE, versions prior to 2.24.4 are vulnerable. Now I
think we're fine in practice, because the build date is reported as
2024-07-05 and 24.4.4 was released 3 weeks ago, but still.
I can't anything in the geoserver documentation that details what
exactly the SNAPSHOT version is. Is there a good way to confirm whether
or not the geoserver is vulnerable to CVE-2024-36401 with some amount
of certainty?
Many Thanks
Max
Hello
A SNAPSHOT version is built on the latest available code base for the branch 2.24.X. As such it should contain the fix for the CVE.
As best practice, I would suggest always use a version with a complete version number.
Regards
Alexandre
Alexandre Gacon
On Mon, 8 Jul 2024 13:04:15 +0200
This seems correct, the 2.24.4 image seems be have been built much
earlier than the 2.24-SNAPSHOT image.
version number.
Thank you for the advice, I have taken it.
Many Thanks
Max
PS. Sorry for the apparent double post to this list. I messed up my
sign-up to this list and thought my first email was discarded :-/.
This, in general, is wrong for any -SNAPSHOT versions of GeoServer as it can be anything after the ".0" tag of a stable branch has been pushed; it depends on the moment the build is done and the moment the code is checked out.
To be certain you will need to check the Git Revision shown on the About page of GeoServer after logging in and compare that to Github, looking at the Build Date is second best.
For the docker images you could look at the image sha1 hash and compare to those listed in https://repo.osgeo.org/#browse/browse:docker:v2%2Fgeoserver%2Ftags
eg. https://repo.osgeo.org/#browse/browse:docker:v2%2Fgeoserver%2Ftags%2F2.24.x
Mark
This was my instinct too, I couldn't find the referenced revision for some reason, though that's on me. I did compare the build date against the release date of 2.24.4 and convinced myself that I was more than likely safe.
I've now pinned to 2.24.4 explicitly, on advice from previous posts to this thread.
Just from the name of the tag, having done no reading at all (which is to say entirely my fault), I just assumed that 2.24.x meant: The latest patch on the 2.24 major.minor version.
Max
Thanks for the fedback,
I wonder if there is some Docker convention for marking nightly builds to make it more obvious?
Jody Garnett
I find the naming convention good enough but perhaps we should make the information shared by Mark more obvious, at least in the documentation.
Perhaps we could also display it in the docker logs.
Alexandre
Jody Garnett
Yeah the docs have a challenge of being generated not knowing the most recently released version…
The manual you download for the 2.25.2 version has the correct examples:
We no longer publish online the docs for each release, only nightly docs, so the online examples are always wrong.
This is something I fixed for mkdocs - compare:
What do you mean about docker tags?
Jody Garnett
Jody Garnett
