I delete and checkout a new version of all the files from
http://svn.geotools.org/geotools/branches/2.3.x/*, i add the settings in the
maven directory. I got no more build failure with missing artefacts thank
you for that...
But i still have the last error about missing package,
do i miss something.
here are the messages
[INFO] Building EPSG Authority Service using HSQL database
[INFO]
[INFO] [clean:clean]
[INFO] Deleting directory D:\@Donnees\Mairie de
paris\Pyramid_builder\plugin\eps
g-hsql\target
g-hsql\target\classes
g-hsql\target\test-classes
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
Downloading:
http://www.ibiblio.org/maven2/hsqldb/hsqldb/1.8.0.1/hsqldb-1.8.0.1.
pom
Downloading:
http://lists.refractions.net/m2/hsqldb/hsqldb/1.8.0.1/hsqldb-1.8.0.
1.pom
Downloading:
http://maven.geotools.fr/repository/hsqldb/hsqldb/1.8.0.1/hsqldb-1.
8.0.1.pom
Downloading:
http://repo1.maven.org/maven2/hsqldb/hsqldb/1.8.0.1/hsqldb-1.8.0.1.
pom
[INFO] [compiler:compile]
Compiling 3 source files to D:\@Donnees\Mairie de
psg-hsql\target\classes
[INFO]
[ERROR] BUILD FAILURE
[INFO]
[INFO] Compilation failure
paris\Pyramid_builder\plugin\epsg-hsql\src\org\geotools\re
ferencing\factory\epsg\HSQLDataSource.java:[40,23] package org.hsqldb.jdbc
does
not exist
ferencing\factory\epsg\HSQLDataSource.java:[75,36] cannot find symbol
symbol: class jdbcDataSource
public class HSQLDataSource extends jdbcDataSource implements DataSource {
ferencing\factory\epsg\HSQLDataSource.java:[75,7]
org.geotools.referencing.facto
ry.epsg.HSQLDataSource is not abstract and does not override abstract method
get
LoginTimeout() in javax.sql.DataSource
ferencing\factory\epsg\HSQLDataSource.java:[145,12] cannot find symbol
symbol : method setDatabase(java.lang.String)
location: class org.geotools.referencing.factory.epsg.HSQLDataSource
ferencing\factory\epsg\HSQLDataSource.java:[154,8] cannot find symbol
symbol : method setUser(java.lang.String)
ferencing\factory\epsg\HSQLDataSource.java:[286,32] cannot find symbol
symbol : method getDatabase()
ferencing\factory\epsg\HSQLDataSource.java:[299,32] cannot find symbol
symbol : variable super
ferencing\factory\epsg\HSQLDataSource.java:[377,25] cannot find symbol
[INFO]
[INFO] Trace
org.apache.maven.BuildFailureException: Compilation failure
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(Defa
ultLifecycleExecutor.java:560)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLi
fecycle(DefaultLifecycleExecutor.java:480)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(Defau
ltLifecycleExecutor.java:459)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHan
dleFailures(DefaultLifecycleExecutor.java:311)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegmen
ts(DefaultLifecycleExecutor.java:278)
at
org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLi
fecycleExecutor.java:143)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:334)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:125)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:280)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at
org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at
org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.CompilationFailureException: Compilation
fail
ure
at
org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompiler
Mojo.java:505)
at
org.apache.maven.plugin.CompilerMojo.execute(CompilerMojo.java:111)
at
org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPlugi
nManager.java:443)
at
ultLifecycleExecutor.java:539)
... 16 more
[INFO]
[INFO] Total time: 4 minutes 12 seconds
[INFO] Finished at: Thu Oct 11 11:31:41 CEST 2007
[INFO] Final Memory: 19M/63M
[INFO]
aaime wrote:
Audaire David ha scritto:
Hi i am trying to test the pyramid builder tool, but i have difficulties
to
build the tools with maven.
below you can see severals step i have to go through . And at the end
don't
know how to go out of the last error message
any help is welcome
Thank's
mvn install:install-file -DgroupId=com.vividsolutions -DartifactId=jts
-Dversion=1.7.1 -Dpackaging=jar -Dfile=D:/Download/lib/jts-1.7.1.jar
mvn install:install-file -DgroupId=edu.oswego -DartifactId=concurrent
-Dversion=1.3.4 -Dpackaging=jar -Dfile=D:/Download/concurrent-1.3.4.jar
mvn install:install-file -DgroupId=com.mockrunner -DartifactId=mockrunner
-Dversion=0.3.6 -Dpackaging=jar -Dfile=D:/Download/mockrunner-0.3.6.jar
mvn install:install-file -DgroupId=oro -DartifactId=oro -Dversion=2.0.8
-Dpackaging=jar -Dfile=D:/Download/oro-2.0.8.jar
mvn install:install-file -DgroupId=hsqldb -DartifactId=hsqldb
-Dversion=1.8.0.1 -Dpackaging=jar -Dfile=D:/Download/hsqldb-1.8.0.1.jar
I dont' understand why you needed to manually install all of these
files in the repo. Maven should be able to download them by itself...
provided it can reach ibiblio, that is.
If maven blocks for minutes trying to download from ibiblio, then I
share your pain. The workaround is to setup some european mirrors
in the maven configuration. In your ${home}/.m2 create a settings.xml
file with the following content:
<settings>
<mirrors>
<mirror>
<id>sateh.com</id>
<url>http://maven.sateh.com/repository</url>
<mirrorOf>central</mirrorOf>
<!-- The Netherlands, Amsterdam -->
</mirror>
<mirror>
<id>cica.es</id>
<url>http://ftp.cica.es/mirrors/maven2</url>
<!-- Spain, Sevilla -->
</mirror>
</mirrors>
</settings>
This should help a little. Then try doing a mvn clean install.
Geoserver-users mailing list
View this message in context: http://www.nabble.com/difficulties-to-build-coverages-tools-tf4601643.html#a13152560
