[Geoserver-users] Disable / alter Geoserver web admin interface for external users
Hi
I am wondering if there is a way to either disable or limit the amount of information displayed when external users are accessing my Geoserver web interface?
They currently are able to view my layers and other settings; I noticed that on some other public geoserver web areas the options on the left hand side have been removed, how am I able to do this?
Thanks
Hi Chris,
GeoServer has a rich security module. Briefly, users can be authenticated and authorized to have access to specific workspaces and data layers with varied read/write/admin options. Additionally, a user can be configured to administer GeoServer. With those options, you can restrict what users would see in the web UI.
http://docs.geoserver.org/latest/en/user/security/index.html
As a note, if you’ve got all your configuration set and don’t require the admin UI, you can disable it via these options: http://docs.geoserver.org/latest/en/user/production/config.html#disable-the-geoserver-web-administration-interface. I think this leaves the REST API available, so it doesn’t remove the need for proper security configuration.
Jim
On 07/11/2016 09:00 AM, Chris Buckmaster wrote:
Hi
Thanks
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
[http://sdm.link/attshape](http://sdm.link/attshape)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Hi Chris,
Have you tried the two options at the bottom of this page:
They will allow you to disable the web admin interface entirely I believe.
Jonathan
---- On Mon, 11 Jul 2016 14:00:29 +0100 Chris Buckmaster<chris.buckmaster@anonymised.com.> wrote ----
Hi
Thanks
http://sdm.link/attshape_______________________________________________
Geoserver-users@anonymised.comrceforge.net
Hi Jonathan
Yes I did notice that but do need access to it within my internal network so I can carry out admin work, I also thought about adding authentication in Windows IIS but probably wouldn’t be a good approach as it might affect access to the data layers themselves.
Will have a look at the information provided by Jim in the previous post.
Chris
From: Jonathan Moules [mailto:jonathan-lists@…7221…]
Sent: 11 July 2016 14:20
To: Chris Buckmaster
Subject: Re: [Geoserver-users] Disable / alter Geoserver web admin interface for external users
Hi Chris,
Jonathan
---- On Mon, 11 Jul 2016 14:00:29 +0100 Chris Buckmaster<chris.buckmaster@…7473…> wrote ----
Hi
Thanks
Hi Chris,
Ah! If you need separate access for an ip block, you might want to explore GeoFence: https://github.com/geoserver/geofence/wiki/Main-concepts.
Not all the features are available in the module version, so you may need to install a stand-alone GeoFence.
Jim
On 07/11/2016 09:22 AM, Chris Buckmaster wrote:
Hi Jonathan
Chris
From: Jonathan Moules [mailto:jonathan-lists@anonymised.com]
Hi Chris,
Jonathan
---- On Mon, 11 Jul 2016 14:00:29 +0100 Chris Buckmaster<chris.buckmaster@anonymised.com> wrote ----
Hi
Thanks
I’ll take a look at that as well thanks Jim.
Sent: 11 July 2016 14:29
Hi Chris,
Jim
Hi Jonathan
Chris
Hi Chris,
Jonathan
Hi
Thanks
Hi Chris,
In that scenario my first thought would be of having multiple instances of GeoServer - a development one (which has the web interface and you can administer), and then a production one which has the web-interface disabled. This removes the risk of mistakes in administering affecting production users.
Alternately, you could also indeed do IIS authentication - just be sure to only require authentication for requests to the /web/ path. This won’t impact any access to your data as they come through other paths.
If you do want (some) other people to be able to administer the system, but only specific layers, then Jim’s solution would be the best. If you want to have everything (for you and other admins) or nothing (for everyone else), then the IIS option will probably be simplest.
Jonathan
---- On Mon, 11 Jul 2016 14:22:36 +0100 Chris Buckmasterchris.buckmaster@anonymised.com wrote ----
Hi Jonathan
Chris
Cc: geoserver-users@anonymised.coms.sourceforge.net
Hi Chris,
Jonathan
Hi
Thanks
Thanks for the advice Jonathan!
Sent: 11 July 2016 14:52
Subject: RE: [Geoserver-users] Disable / alter Geoserver web admin interface for external users
Hi Chris,
Jonathan
---- On Mon, 11 Jul 2016 14:22:36 +0100 Chris Buckmaster<chris.buckmaster@…7473…> wrote ----
Hi Jonathan
Chris
Hi Chris,
Jonathan
Hi
Thanks
If the instances are different maybe you can just remove the WEB module JARs from the production one.
On Mon, Jul 11, 2016 at 3:53 PM, Chris Buckmaster <chris.buckmaster@anonymised.com> wrote:
Hi Chris,
Jonathan
---- On Mon, 11 Jul 2016 14:22:36 +0100 Chris Buckmaster<chris.buckmaster@anonymised.com73…> wrote ----
Hi Jonathan
Chris
Hi Chris,
Jonathan
---- On Mon, 11 Jul 2016 14:00:29 +0100 Chris Buckmaster<chris.buckmaster@anonymised.com73…> wrote ----
Hi
Thanks
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
