Hi
We used to be able to disable the internal GeoWebCache entirely by removing any *gwc* jar files from the GeoServer directory prior to 2.16.1.
GeoServer 2.16.1 won’t even start after removing the GWC jars – I’ve uploaded the logs here: https://gist.github.com/GeoTob/9f7e6c4b9b2f8b324a9f695f2633be98
I’m not sure if that’s a bug/regression (happy to open a ticket!) or by design, so what’s the recommended way to entirely disable the internal GeoWebCache these days?
Thanks
Hi Tobias,
thinking out loud, did you also remove the gs-rest-wmts jar? WMTS services are also provided by GWC
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
