[Geoserver-users] Display EPSG:4326 wms over EPSG:25832 GWCbaselayer seriously wrong!
I sent this originally to the openlayers lists…but it is probably a geoserver issue.
I have discovered that one of my projects does not display WMS Layers over a GWC basemap anymore. It used to work fine, but something has obviously been changed …I suspect in geoserver but I´m not sure.
http://maps.zgb.de/geoportal/os.html
This is a mashup demostrating what I mean…the basemap is from GWC in geoserver. The Basemap is defined as EPSG:25832. I used to be able to easily define a wms layer and this would be displayed without any trouble over the basemap. Now it doesn´t. I will only display when the basemap is in the same native projection!!!
I thought that geoserver would automatically redefine the wms projection based on the basemaps options…am I right?
so why doesn´t it work here?
Thanks for any help,
Robert
----- Weitergeleitete Message -----
Von: Arnd Wippermann arnd.wippermann@anonymised.com
An: ‘Robert Buckley’ robertdbuckley@anonymised.com
CC: openlayers-users@anonymised.com26…
Gesendet: 22:08 Mittwoch, 24.Oktober 2012
Betreff: AW: [OpenLayers-Users] Display EPSG:4326 wms over EPSG:25832 GWCbaselayer
There seems something wrong with GeoServer transformation to EPSG:25832. The data is shifted ca. 3 Million to east.
http://maps.zgb.de/geoserver/wms
?SERVICE=WMS
&LAYERS=zgb%3ABrutvoegel_2010%2Czgb%3AGrenzen_mg
&FORMAT=image%2Fpng
&VERSION=1.1.1
&TRANSPARENT=true
&REQUEST=GetMap
&STYLES=
&EXCEPTIONS=application%2Fvnd.ogc.se_inimage
&SRS=EPSG%3A25832
&BBOX=3600489.7789,5792092.2535,3678761.29585,5870363.77045
&WIDTH=256
&HEIGHT=256
The request will show some data, but the BBOX is not in EPSG:25832 coordinates:
http://maps.zgb.de/geoserver/wms?SERVICE=WMS&LAYERS=zgb%3ABrutvoegel_2010%2Czgb%3AGrenzen_mg&FORMAT=image%2Fpng&VERSION=1.1.1&TRANSPARENT=true&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A25832&BBOX=3600489.7789,5792092.2535,3678761.29585,5870363.77045&WIDTH=256&HEIGHT=256
It’ a question for GeoServer.
Arnd
I remembered that I did some testing a while back with custom coordinate operations.
I had tried to create an operation between EPSG:31467 and EPSG:25832 using the BETA2007.gsb file.
It seems that it is this configuration that messed up my system…or I simply did it wrong.
This was the content of “epsg_operations.,properties”
31467,25832=PARAM_MT[“NTv2”, \PARAMETER[“Latitude and longitude difference file”, “BETA2007.gsb”]]
and the BETA2007.gsb was in the same folder.
Once I had removed these files and restarted tomcat6 the wms layers were once again displayed.
Robert
Von: Robert Buckley robertdbuckley@anonymised.com
An:geoserver-users@lists.sourceforge.netgeoserver-users@anonymised.comorge.net
Gesendet: 7:21 Donnerstag, 25.Oktober 2012
Betreff: [Geoserver-users] Display EPSG:4326 wms over EPSG:25832 GWCbaselayer seriously wrong!
Robert
?SERVICE=WMS
&FORMAT=image%2Fpng
&VERSION=1.1.1
&TRANSPARENT=true
&REQUEST=GetMap
&STYLES=
&SRS=EPSG%3A25832
&WIDTH=256
&HEIGHT=256
Arnd
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
Geoserver-users mailing list
Geoserver-users@anonymised.comurceforge.net
On Thu, Oct 25, 2012 at 9:11 AM, Robert Buckley
operations.
It seems that it is this configuration that messed up my system...or I
This was the content of "epsg_operations.,properties"
31467,25832=PARAM_MT["NTv2", \PARAMETER["Latitude and longitude difference
file", "BETA2007.gsb"]]
While not impossible, this is odd: you are trying to use a grid to
transform between two
projected systems.
All the grids I've seen so far are used to switch between geographic
ones, normally
the file is a latitude/longitude grid shift, in your case maybe
between 4314 and 4258,
the geographic systems under the projected ones:
http://prj2epsg.org/epsg/31467
http://prj2epsg.org/epsg/25832
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
<andrea.aime@anonymised.com>:
ones, normally
+1.
BETA2007.gsb is defined between EPSG:4314 and EPSG:4258.
Look for code 15948 in http://www.epsg-registry.org/
Oscar.
EPSG:4314 and EPSG:4258 are unknown to me
According to this …
http://crs.bkg.bund.de/crseu/crs/descrtrans/BeTA/de_dhdn2etrs_beta.php
The beta2007 is used for
Quell-Koordinatenreferenzsystem Identifikator DE_DHDN / GK_3
Ziel-Koordinatenreferenzsystem Identifikator ETRS89 / UTM
Quell = Source
Ziel = Target
…“BeTA2007 enthält implizit die Konvertierung (Wechsel des Koordinatensystems) von DE_DHDN / GK_3 nach DE_DHDN / Lat-Lon und nach der Transformation mit NTv2 (Wechsel des geodätischen Datums) zu ETRS89 / Lat-Lon die Konvertierung nach ETRS89 / UTM”
between DH:DHDN / GK zone 3 to ETRS89 / UTM
Therefore EPSG:31467 to EPSG:25832
Or am i missing something?
yours,
Rob
Von: Oscar Fonts <oscar.fonts@anonymised.com…>
An:geoserver-users@lists.sourceforge.netgeoserver-users@lists.sourceforge.net
CC: Robert Buckley robertdbuckley@anonymised.com; Andrea Aime andrea.aime@anonymised.com
Gesendet: 15:29 Donnerstag, 25.Oktober 2012
Betreff: Re: [Geoserver-users] Display EPSG:4326 wms over EPSG:25832 GWCbaselayer seriously wrong!SOLVED
All the grids I’ve seen so far are used to switch between geographic
ones, normally
+1.
Oscar.
On Thu, Oct 25, 2012 at 4:18 PM, Robert Buckley <robertdbuckley@anonymised.com4…> wrote:
According to this …
I’ve translated that page with Google in italian and what it says is that the
transformation is lat/lon to lat/lon, so not between the two projected
systems, but between their base geographic reference systems instead,
which are EPSG:4314 and EPSG:4258 respectively.
Ing. Andrea Aime
@geowolf
Technical Lead
