I installed docker station (v23.0.5) on my windows 10 machine and then followed instructions from https://docs.geoserver.org/latest/en/user/installation/docker.html so I pulled the image (i used a few different versions also tried kartoza/geoserver) and then I started a container simply copy-pasting the docker commands. Every case of my containers, the Geoserver instance is running ok on localhost:8080/geoserver/web but anything I try, such as to create a new workspace or perform any action like updating a layer or clearing the cache, nothing happens. I get these errors on my dev tools
DevTools failed to load source map: Could not load content for chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/browser-polyfill.js.map: System error: net::ERR_FILE_NOT_FOUND
DevTools failed to load source map: Could not load content for http://localhost:8080/geoserver/web/wicket/resource/org.geoserver.web.GeoServerBasePage/css/bootstrap-utilities.min.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
and on geoserver logs I get
[resource.ResourceReferenceRegistry] - A ResourceReference wont be created for a resource with key [scope: org.geoserver.web.GeoServerBasePage; name: css/bootstrap-utilities.min.css.map; locale: null; style: null; variation: null] because it cannot be located.
or sometimes I get a message “an illegal reflective access operation has occurred” and all following illegal operations will not be permitted.
I have also tried installing different versions of Java and geoservers on my machine without using docker and I get the same errors.
Interestingly enough, last week I installed geoserver 2.15 on my windows machine which worked OK and I was able to create workspaces, add stores like postgis and publish layers etc. and I did see this behaviour (stated above) but it got fixed when I re-installed java and geoserver. BUT there was an update on my windows machine and ever since I am constantly getting the errors mentioned above.
I looked around in forums and in the geoserver-users list but could not find something relevant. I don’t have much experience with java so it’s not easy to understand why it can not locate the css/bootstrap-utilities.min.css.map resource. I also had a look at a tomcat setting named useRelativeRedirects) but haven’t fiddled with it yet.
I will keep trying different approaches but in case someone can replicate or has any relevant info, I would appreciate it!
I hope the above makes sense and I would be happy to provide further info if required. Thanks in advance!
Kind regards,
Antony
