[Geoserver-users] Documentation for integration of ORACLE Georaster data in geosever
We are trying to integrate ORACLE georaster data into our Geoserver instance using the Georaster Plugin (https://docs.geoserver.org/2.19.x/en/user/community/imagemosaic-jdbc/oraclegeoraster.html).
At the moment we are stuck in our efforts, and unfortunately the provided documentation link (https://docs.geotools.org/latest/userguide/library/coverage/oracle.html) does not work.
Questions:
  • Could someone share that documentation (or a working link to it) with us? I cannot find any other documentation in the internet.
  • Who would be interested in giving us short initial support to integrate our ORACLE georaster data into our Geoserver?
Thanks, best regards,
Wolfgang Tinkl
Op 02-11-2022 om 10:59 schreef Tinkl Wolfgang:
With 2.19.x being EOL and IIRC oracle georaster support having been dropped in Geotools 24.x I think you should reconsider your choice.
The source of the document you are looking for is
https://github.com/geotools/geotools/blob/23.x/docs/user/library/coverage/oracle.rst
- M
It has indeed been dropped (all database raster plugins are) due to lack of a maintainer
(nobody volunteered, nor anyone provided funding for another developer to become acquainted, and step up to be the new maintainer).
This could change with the necessary resources, e.g., the code is not gone forever, it can be recovered
from the version control history, cleaned up and put back in working order.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
