[Geoserver-users] Does geoserver support multiple overview files for one GeoTIFF?
That structure is most usable for constructing overviews from different data sources, not by subsampling higher resolution data. Nice trick for making one virtual topomap with different rendering rules for different scales.
I can see that there is something that supports GDAL virtual rasters in https://github.com/geosolutions-it/imageio-ext/tree/master/plugin/gdal/gdalvrt. On the other hand, it is possible to collect overviews from different sources by using GDAL VRT format http://www.gdal.org/gdal_vrttut.html#gdal_vrttut_overviews and http://osgeo-org.1560.x6.nabble.com/gdal-dev-Scale-dependent-VRT-for-overviews-td4966814.html.
So perhaps GeoServer can support the structure that you have but developers just don’t know it yet.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime [mailto:andrea.aime@…1107…]
Lähetetty: 23. huhtikuuta 2018 15:41
Vastaanottaja: Mark Prins <mc.prins@…84…>
Kopio: GeoServer Mailing List List geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Does geoserver support multiple overview files for one GeoTIFF?
Hi Mark,
never seen a structure like that ( .ovr.ovr.ovr… really really really!?) so I guess you’re right, it’s currently not supported :slight_smile:
On Mon, Apr 23, 2018 at 2:29 PM, Mark Prins <mc.prins@…84…> wrote:
I have a geotiff with mutliple overviews (see below gdalinfo output) and I’m wondering if these are used? Looking at the MaskOverviewProvider code in Geotools [1] I suspect not and only the first .ovr will be used.
Am I correct?
TIA, Mark
[1] https://github.com/geotools/geotools/blob/master/modules/library/coverage/src/main/java/org/geotools/coverage/grid/io/imageio/MaskOverviewProvider.java#L118
Driver: GTiff/GeoTIFF
Files: ./Leiden_2017.tiff
./Leiden_2017.tiff.ovr
./Leiden_2017.tiff.ovr.ovr
./Leiden_2017.tiff.ovr.ovr.ovr
./Leiden_2017.tiff.ovr.ovr.ovr.ovr
Size is 175000, 200000
Coordinate System is:
PROJCS[“Amersfoort / RD New”,
GEOGCS[“Amersfoort”,
DATUM[“Amersfoort”,
SPHEROID[“Bessel 1841”,6377397.155,299.1528128000008,
AUTHORITY[“EPSG”,“7004”]],
TOWGS84[565.417,50.3319,465.552,-0.398957,0.343988,-1.8774,4.0725],
AUTHORITY[“EPSG”,“6289”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4289”]],
PROJECTION[“Oblique_Stereographic”],
PARAMETER[“latitude_of_origin”,52.15616055555555],
PARAMETER[“central_meridian”,5.38763888888889],
PARAMETER[“scale_factor”,0.9999079],
PARAMETER[“false_easting”,155000],
PARAMETER[“false_northing”,463000],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“28992”]]
Origin = (89500.000000000000000,467000.000000000000000)
Pixel Size = (0.040000000000000,-0.040000000000000)
Metadata:
AREA_OR_POINT=Area
COLORSPACE=RGB
COMPRESSION_RATE_TARGET=4
VERSION=2
Image Structure Metadata:
COMPRESSION=YCbCr JPEG
INTERLEAVE=PIXEL
SOURCE_COLOR_SPACE=YCbCr
Corner Coordinates:
Upper Left ( 89500.000, 467000.000) ( 4d25’46.80"E, 52d11’17.62"N)
Lower Left ( 89500.000, 459000.000) ( 4d25’52.35"E, 52d 6’58.77"N)
Upper Right ( 96500.000, 467000.000) ( 4d31’55.32"E, 52d11’20.45"N)
Lower Right ( 96500.000, 459000.000) ( 4d32’ 0.28"E, 52d 7’ 1.59"N)
Center ( 93000.000, 463000.000) ( 4d28’53.69"E, 52d 9’ 9.65"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Description = Red
Overviews: 87500x100000, 43750x50000, 21875x25000, 10938x12500, 5469x6250, 2735x3125, 1368x1563, 684x782, 342x391
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Description = Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Description = Blue
Disclaimer;
This message is just a reflection of what I thought at the time of sending. The message may contain information that is not intended for you or that you don’t understand.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
2018-04-23 15:05 GMT+02:00 Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com>:
scales.
We do this because it speeds up generating overviews quite a bit (taking an
overview to generate an overview instead of sampling the whole tiff - this
used to be an issue with gdal, not sure if it still is), and makes
mapserver a little less resource hungry, because the .ovr files get smaller
each round (each next one is about 25% of the previous).
gdaladdo -ro <some other options> some.tiff 2
gdaladdo -ro <some other options> some.tiff.ovr 2
gdaladdo -ro <some other options> some.tiff.ovr.ovr 2
gdaladdo -ro <some other options> some.tiff.ovr.ovr.ovr 2
gdaladdo -ro <some other options> some.tiff.ovr.ovr.ovr 2 4 8 16 32 64
Building on gdal mapserver picks this up fine, but this particular case
requires geoserver.
I'll just kick off a new gdaladdo for now.
Thanks, Mark
