[Geoserver-users] Does GeoServer support SDE's ST_GEOMETRY?
ST_GEOMETRY is an ESRI format - not sure if it is standards-compliant.
We use Oracle’s SDO_GEOMETRY type - seems to work OK
with both SDE and Geoserver, and you have the advantage of using
SQL for data loading and querying if you want.
cheers,
Chris
---- Original Message ----
From: “Freeman, Aleda (EEA)” Aleda.Freeman@anonymised.com
To: “geoserver-users@anonymised.comsourceforge.net” geoserver-users@lists.sourceforge.net
Sent: Fri, Jul 2, 2010, 21:37 PM
Subject: [Geoserver-users] Does GeoServer support SDE’s ST_GEOMETRY?
We are currently using ESRI SDE with the BLOB geometry. (SDE 9.2 on Oracle 10.2).
(Actually my data librarian clarifies: BLOB is what is used mostly for geometry storage. A few keywords (like USERS) use SDELOB (a newer term than BLOB).)
We are planning to put SDE 10 (and Oracle 11) on a brand new server and load it up with data.
My boss is now interested in ST_GEOMETRY (I guess it has advantages such as SQL access).
http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geodatabases/the_st_g432914457.htm
http://webhelp.esri.com/arcgisserver/9.3/java/geodatabases/st_geom-270510096.htm
I looked around in GeoServer and GeoTools documentation but I couldn’t find an answer to the question:
Does GeoServer support ST_GEOMETRY for SDE? Or will it in the near future?
Aleda Freeman, GISP, Web Mapping Services Manager
MassGIS
Information Technology Division
251 Causeway St. 5th floor
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
http://www.mass.gov/mgis - MassGIS
http://lyceum.massgis.state.ma.us - Webservices Wiki
MassGIS is the Commonwealth’s Office of Geographic Information
A Technology and Data Resource for GIS Users in the Commonwealth
Incoming and outgoing emails are checked for viruses
by Sophos AntiVirus.
This email may contain confidential information which is
intended for the named recipient(s) only.  If you are
not the named recipient you should not take any action in
relation to this email, other than to notify us that you
have received it in error.
Lynx Information Systems Ltd
93-99 Upper Richmond Rd
London SW15 2TG
United Kingdom
Web: http://www.lynxinfo.co.uk
Email: lynx@anonymised.com
Tel: +44 (0)20 8780 2634
Fax: +44 (0)20 8780 0931
Registered in England Number 2454130
VAT Number GB 561 8979 88
Well… I’ve been reading…
This page: http://argyron.limnology.wisc.edu:8099/arcgismanager/help/index.htm#geodatabases/an_over1698501291.htm
says that the
ArcSDE Spatial Type ST_Geometry
  • Utilizes the ArcSDE extended spatial type for managing vector data
  • Supports the ISO and OGC SQL API for spatial
  • Based on the ISO SQL MM specification for spatial
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
From: geoserver-users-bounces@lists.sourceforge.net [mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Chris Morgan
Sent: Friday, July 02, 2010 5:04 PM
Subject: Re: [Geoserver-users] Does GeoServer support SDE’s ST_GEOMETRY?
cheers,
Chris
To: “geoserver-users@lists.sourceforge.net” geoserver-users@lists.sourceforge.net
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
London SW15 2TG
United Kingdom
Hi Aleda,
my understanding is the ST_GEOMETRY should be supported out of the box. It is just one of the underlying geometry storage formats ESRI supports, but it's transparent for the client API.
Gabriel.
On 7/2/10 6:30 PM, Freeman, Aleda (EEA) wrote:
Well... I've been reading...
says that the
  * Utilizes the ArcSDE extended spatial type for managing vector data
  * Supports the ISO and OGC SQL API for spatial
  * Based on the ISO SQL MM specification for spatial
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
http://lyceum.massgis.state.ma.us/> - Webservices Wiki
MassGIS is the Commonwealth's Office of Geographic Information
Subject: Re: [Geoserver-users] Does GeoServer support SDE's ST_GEOMETRY?
We use Oracle's SDO_GEOMETRY type - seems to work OK
cheers,
Chris
From: "Freeman, Aleda (EEA)"<Aleda.Freeman@anonymised.com>
To: "geoserver-users@lists.sourceforge.net"<geoserver-users@lists.sourceforge.net>
Subject: [Geoserver-users] Does GeoServer support SDE's ST_GEOMETRY?
I looked around in GeoServer and GeoTools documentation but I couldn't find an answer to the question:
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
London SW15 2TG
United Kingdom
Gabriel Roldan
OpenGeo - http://opengeo.org
That's not quite right as I understand it.
If you use SDE as your Geoserver source, then ST_GEOMETRY will be
implicitly supported, along with the other formats that SDE supports.
But (at present), you cannot dispense with the intermediary SDE layer
for access by Geoserver.
Whereas if you use Oracle's SDO_GEOMETRY type, you don't need
SDE at all. Presumably someone could create an ESRI ST_GEOMETRY
data store for Geoserver, but at present, there isn't one.
cheers,
Chris
----- Original Message ----- From: "Gabriel Roldan" <groldan@anonymised.com>
To: "Freeman, Aleda (EEA)" <Aleda.Freeman@anonymised.com>
Cc: "'Chris Morgan'" <chris@anonymised.com>; <geoserver-users@lists.sourceforge.net>
Sent: Monday, July 05, 2010 5:10 PM
Hi Aleda,
Gabriel.
says that the
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
http://lyceum.massgis.state.ma.us/&gt; - Webservices Wiki
cheers,
Chris
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
London SW15 2TG
United Kingdom
Gabriel Roldan
London SW15 2TG
United Kingdom
OK, that's good I think. We're not looking to get rid of SDE, only use a different underlying geometry type next time.
I guess I should probably try to set up a test layer and make sure GeoServer can access it.
I wonder if we can mix geometry types in one SDE instance. I'll check with our SDE administrator.
I'll let you know how it works out.
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
-----Original Message-----
Sent: Monday, July 05, 2010 12:22 PM
If you use SDE as your Geoserver source, then ST_GEOMETRY will be implicitly supported, along with the other formats that SDE supports.
But (at present), you cannot dispense with the intermediary SDE layer for access by Geoserver.
Whereas if you use Oracle's SDO_GEOMETRY type, you don't need SDE at all. Presumably someone could create an ESRI ST_GEOMETRY data store for Geoserver, but at present, there isn't one.
cheers,
Chris
Cc: "'Chris Morgan'" <chris@anonymised.com>; <geoserver-users@anonymised.com.net>
Hi Aleda,
Gabriel.
This page:
says that the
Aleda Freeman, GISP, Web Mapping Services Manager MassGIS Information
Technology Division
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
- Webservices Wiki MassGIS is the Commonwealth's Office of Geographic
Information A Technology and Data Resource for GIS Users in the
Commonwealth
Chris Morgan
We use Oracle's SDO_GEOMETRY type - seems to work OK with both SDE
and Geoserver, and you have the advantage of using SQL for data
cheers,
Chris
To:
"geoserver-users@lists.sourceforge.net"<geoserver-users@anonymised.com
orge.net>
Oracle 10.2).
0510096.htm
future?
Technology Division
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
http://lyceum.massgis.state.ma.us - Webservices Wiki MassGIS is the
Commonwealth's Office of Geographic Information A Technology and Data
Incoming and outgoing emails are checked for viruses by Sophos
AntiVirus.
This email may contain confidential information which is intended for
the named recipient(s) only. If you are not the named recipient you
should not take any action in relation to this email, other than to
notify us that you have received it in error.
London SW15 2TG
United Kingdom
Gabriel Roldan
Incoming and outgoing emails are checked for viruses by Sophos AntiVirus.
This email may contain confidential information which is intended for the named recipient(s) only. If you are not the named recipient you should not take any action in relation to this email, other than to notify us that you have received it in error.
London SW15 2TG
United Kingdom
This SF.net email is sponsored by Sprint What will you do first with EVO, the first 4G phone?
Visit sprint.com/first -- http://p.sf.net/sfu/sprint-com-first
Geoserver-users mailing list
Yes, you can have different layers using different geometry
types in a single SDE instance.
cheers,
Chris
----- Original Message ----- From: "Freeman, Aleda (EEA)" <Aleda.Freeman@anonymised.com>
To: "'Chris Morgan'" <chris@anonymised.com>
Cc: <geoserver-users@lists.sourceforge.net>
Sent: Tuesday, July 06, 2010 2:14 PM
Subject: RE: [Geoserver-users] Does GeoServer support SDE's ST_GEOMETRY?
can access it.
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
Morgan
cheers,
Chris
Hi Aleda,
Gabriel.
This page:
says that the
Technology Division
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
Commonwealth
Chris Morgan
cheers,
Chris
To:
orge.net>
Oracle 10.2).
0510096.htm
future?
Technology Division
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
AntiVirus.
London SW15 2TG
United Kingdom
Gabriel Roldan
London SW15 2TG
United Kingdom
the first 4G phone?
London SW15 2TG
United Kingdom
Correct. Would be a cool feature to have, to let people drop SDE even if they didn't configure it to use the spatial backend's native stuff. But probably a non-trivial amount of work, as it'd probably involve a bit of reverse engineering.
Chris
cheers,
Chris
To: "Freeman, Aleda (EEA)"<Aleda.Freeman@anonymised.com>
Cc: "'Chris Morgan'"<chris@anonymised.com>;
Hi Aleda,
Gabriel.
This page:
says that the
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
Webservices Wiki
Morgan
cheers,
Chris
To:
Oracle 10.2).
than BLOB).)
as SQL access).
future?
MassGIS
Boston, MA 02114
phone: 617-626-1193
fax: 617-626-1249
London SW15 2TG
United Kingdom
Gabriel Roldan
London SW15 2TG
United Kingdom
I tried the SDE geometry type ST_Geometry and unfortunately it doesn't work 100% (but it's close, it seems to be a limited where clause/filter issue).
Oracle 10.2, SDE 9.2 SP5, GeoServer 2.0.1 with SDE 9.3 jars.
Here's what I'm seeing in the few tests I've done, with more details at the bottom on errors.
Should I create a bug report? I not sure if it's one or two based on slightly different errors I've seen so far.
What works:
1. Basic WMS drawing in OpenLayers
2. WMS with a spatial filter works - Intersects
3. WMS with SLD using Rules and Filters
4. WFS DescribeFeatureType
5. WFS GetFeature URL with PropertyName to return one field
6. WFS GetFeature URL with CQL Filter
7. WFST Insert poly
What has errors:
8. WFS GetFeature shapefile extract causes error in geoserver.log:
        SDE error -51][Error desc=DATABASE LEVEL ERROR OCCURRED
9. WFS GetFeature with Excel output causes error in geoserver.log:
      This error is identical to the one in #8.
        Excel file is produced that contains an attribute field heading rows but no data rows
10. WFS XML GetFeature with Filter error in geoserver.log:
        Starts out with SDE error -42][Error desc=USER SPECIFIED WHERE CLAUSE IS INVALID
        and then goes into the same error as #8.
More details on #8:
request:
http://maps.massgis.state.ma.us/geoserver/wfs?request=GetFeature&service=wfs&version=1.0.0&typename=massgis:AFREEMAN.COUNTIES_POLY_ST_G&outputformat=SHAPE-ZIP
geoserver.log:
2010-07-15 10:37:31,347 INFO [geoserver.wfs] -
Request: getFeature
        handle = null
        service = wfs
        version = 1.0.0
        baseUrl = http://maps.massgis.state.ma.us:80/geoserver/
        providedVersion = null
        query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: nu
ll, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://massgis.state.ma.us/featuretype\}
AFREEMAN.COUNTIES_POLY_ST_G])]
        maxFeatures = null
        outputFormat = SHAPE-ZIP
        resultType = results
        traverseXlinkDepth = null
        traverseXlinkExpiry = null
        formatOptions = {}
2010-07-15 10:37:31,437 WARN [data.ArcSDEQuery] - Error fetching row for AFREEMAN.COUNTIES_POLY_ST_G[
Filter: Filter.INCLUDE
where clause sent: null
geometry filter:Filter.INCLUDE
org.geotools.arcsde.ArcSdeException: [SDE error -51][Error desc=DATABASE LEVEL ERROR OCCURRED.][Extended desc=
        at org.geotools.arcsde.session.Session.issue(Session.java:268)
        at org.geotools.arcsde.session.Session.fetch(Session.java:704)
        at org.geotools.arcsde.session.Session.fetch(Session.java:700)
        at org.geotools.arcsde.data.ArcSDEQuery.fetch(ArcSDEQuery.java:828)
        at org.geotools.arcsde.data.ArcSDEAttributeReader.hasNext(ArcSDEAttributeReader.java:182)
        at org.geotools.data.DefaultFeatureReader.hasNext(DefaultFeatureReader.java:108)
        at org.geotools.data.MaxFeatureReader.hasNext(MaxFeatureReader.java:84)
        at org.geotools.data.store.FeatureReaderIterator.hasNext(FeatureReaderIterator.java:51)
        at org.geoserver.feature.RetypingFeatureCollection$RetypingIterator.hasNext(RetypingFeatureCollection.java:116)
        at org.geoserver.wfs.response.RemappingFeatureCollection$RemappingIterator.hasNext(RemappingFeatureCollection.ja
va:129)
va:129)
        at org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.java:260)
        at org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefile(ShapeZipOutputFormat.java:244)
        at org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:160)
        at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:726)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
        at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java
:48)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
        at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
        at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
        at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.ja
va:249)
        at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
        at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
        at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
        at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
        at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:769)
        at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:698)
        at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:891)
        at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
        at java.lang.Thread.run(Thread.java:619)
Caused by: com.esri.sde.sdk.client.SeException:
        at com.esri.sde.sdk.client.k.v(Unknown Source)
        at com.esri.sde.sdk.client.k.d(Unknown Source)
        at com.esri.sde.sdk.client.SeQuery.fetch(Unknown Source)
        at org.geotools.arcsde.session.Session$4.execute(Session.java:708)
        at org.geotools.arcsde.session.Session$4.execute(Session.java:706)
        at org.geotools.arcsde.session.Session.issue(Session.java:265)
        ... 68 more
More details on #10:
request:
<wfs:GetFeature xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://giswebservices.massgis.state.ma.us/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; service="WFS" version="1.0.0">
        <wfs:Query typeName="massgis:AFREEMAN.COUNTIES_POLY_ST_G" xmlns:massgis="http://massgis.state.ma.us/featuretype&quot;&gt;
                <ogc:Filter>
                        <ogc:PropertyIsEqualTo>
                                <ogc:PropertyName>COUNTY</ogc:PropertyName>
                                <ogc:Literal>ESSEX</ogc:Literal>
                        </ogc:PropertyIsEqualTo>
                </ogc:Filter>
        </wfs:Query>
</wfs:GetFeature>
geoserver.log:
2010-07-15 10:57:56,007 INFO [geoserver.wfs] -
Request: getFeature
        handle = null
        service = WFS
        version = 1.0.0
        query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: [
COUNTY = ESSEX ], sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://massgis.state.ma.
us/featuretype}AFREEMAN.COUNTIES_POLY_ST_G])]
        maxFeatures = null
        outputFormat = GML2
        formatOptions = {}
2010-07-15 10:57:56,017 ERROR [data.ArcSDEQuery] - ***********************
tables: [AFREEMAN.COUNTIES_POLY_ST_G]
filter: Filter.INCLUDE
SQL: AFREEMAN.COUNTIES_POLY_ST_G.COUNTY = 'ESSEX'
org.geotools.arcsde.ArcSdeException: [SDE error -42][Error desc=USER SPECIFIED WHERE CLAUSE IS INVALID.][Extended desc=
        at org.geotools.arcsde.data.ArcSDEQuery.calculateQueryExtent(ArcSDEQuery.java:668)
        at org.geotools.arcsde.data.ArcSDEQuery.calculateQueryExtent(ArcSDEQuery.java:597)
        at org.geotools.arcsde.data.ArcSdeFeatureSource.getBounds(ArcSdeFeatureSource.java:187)
        at org.geotools.arcsde.data.ArcSdeFeatureSource.getBounds(ArcSdeFeatureSource.java:165)
        at org.geotools.arcsde.data.ArcSdeFeatureCollection.getBounds(ArcSdeFeatureCollection.java:85)
        at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:490)
        at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
        at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
        at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
        at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
        at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
        at org.geoserver.wfs.xml.GML2OutputFormat.encode(GML2OutputFormat.java:265)
        at org.geoserver.wfs.xml.GML2OutputFormat.write(GML2OutputFormat.java:284)
:48)
        at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
va:249)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at com.esri.sde.sdk.client.k.a(Unknown Source)
        at com.esri.sde.sdk.client.SeQuery.calculateLayerExtent(Unknown Source)
        at org.geotools.arcsde.data.ArcSDEQuery$3.execute(ArcSDEQuery.java:707)
        at org.geotools.arcsde.data.ArcSDEQuery$3.execute(ArcSDEQuery.java:668)
        ... 67 more
2010-07-15 10:57:56,017 WARN [data.ArcSDEQuery] - Error fetching row for AFREEMAN.COUNTIES_POLY_ST_G[
Filter: [ COUNTY = ESSEX ]
where clause sent: AFREEMAN.COUNTIES_POLY_ST_G.COUNTY = 'ESSEX'
Ok... sigh, I had problems with calculating the query bounds on Oracle before.
A single jira issue would be ok, with these same logs attached.
Gabriel
What works:
7. WFST Insert poly
What has errors:
More details on #8:
request:
geoserver.log:
Request: getFeature
         handle = null
         service = wfs
         version = 1.0.0
         maxFeatures = null
         formatOptions = {}
va:129)
va:129)
:48)
va:249)
         ... 68 more
request:
                 <ogc:Filter>
                 </ogc:Filter>
         </wfs:Query>
</wfs:GetFeature>
geoserver.log:
Request: getFeature
         handle = null
         service = WFS
         version = 1.0.0
         maxFeatures = null
         outputFormat = GML2
         formatOptions = {}
:48)
va:249)
         ... 67 more
Gabriel Roldan
